Well guys, here is the problem. So i got a Q6600, and it doesnt OC past 3005MHz.
I am running it at Auto Voltage, which runs it at 1.256v when 100% load, under Prime95. It passes the tests when running at 1.256v and 3005 mhz, but i cant push it any farther. I got a 333mhz Bus Speed and multiplier x9. I am using 4 gigs of PGi DDR2-800U ram. The GPU i have is a GT 8800. And the temps are really low!! 52 max for cores #0 and #1, #2 and #3 run at 48c when under load in Prime95. So what's wrong? I have tried other core voltages, just cant make it work at 3.2 ghz. And yes, it is a G0 version. I guess its just too old.. The MOBO i am using is a ASUS P5K. And i am using a X Type 600w psu, LC-Power. So the wattages are far away from max with that GT 8800. I cant imagine other else than its the age of the CPU or then i didnt win in the Silicon Lottery. :/
