Intel core i5 Overclock problem
william.hultbrant
I just tried to overclock my i5 processor from 3,4 GHz to 4GHz and my pc crashed and now it wont boot, any tips how i can fix this and why this happend? need help asap!
Turn off PSU (there is a "- O" switch) and remove your cmos battery for a while and put back in. Touch metal before you do this to avoid static. it looks like: https://www.google.com/search?q=cmos+battery&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjLi-PVw-vWAhWC4yYKHQwSD34Q_AUICygC&biw=1920&bih=949#imgrc=uToBcSDlezfimM:
make sure the PSU IS UNPLUGGED ANS SWITCHED OFF. Take out the CMOS battery, wait 15 seconds. Put back CMOS battery and plug in pSU and switch it on and turn on the computer and it should boot. :)
thank you so much, really appreaciated :)
I do it all the time, that's what it's there for. Either you did something wrong or had a faulty mobo. It's a lot easier that removing the CMOS battery, especially if you mobo is laid out like mine with the CMOS battery directly behind the GPU, meaning I'd have to take my graphics card out to remove it.
