Coming in 2021, Alder Lake CPUs will have two different kinds of processor cores.
Intel Dishes on Alder Lake-S: First x86 Hybrid CPU for Desktops : Read more
The scheduled forum maintenance has now been completed. If you spot any issues, please report them here in this thread. Thank you!
But, why should a desktop user without mobile power/heat constraints want the complexity and lower performance of mixing in smaller mobile cores?
In my opinion they can't deliver 16 cores because of yields problem, so they are putting 8 smartphone cores in the level of cortex a76 and calling it a "16 cores" cpu.But, why should a desktop user without mobile power/heat constraints want the complexity and lower performance of mixing in smaller mobile cores?
The only cases I can think if is if these are extremely cheap (probably unlikely due to the complexity), or if they are mixing 8 big cores with, like, 56 small cores in mainstream desktop.
Thin clients? Those tend to just use the mobile chips because the form factor is TDP limited, Right?
Intel wants to top out at 8 big / 8 Bigger? Ok ... Meanwhile Ryzen is over a year deep into 16 Biggest. So, I really don't understand what they are trying to target.
These CPU's aren't supposed to hit the market for another year and have been in the design phase for a while. So unless Intel was certain there would be yield issues years in advance when they decided to choose this design, it's unlikely the reason. Alder Lake is supposed to use Golden Cove cores which according to Jim Keller are "significantly bigger" than Sunny Cove cores. This in conjunction with Golden Cove originally being designed for 7nm, and getting back ported to 10nm for Alder Lake likely has more to do with why Intel is going with big-little.In my opinion they can't deliver 16 cores because of yields problem, so they are putting 8 smartphone cores in the level of cortex a76 and calling it a "16 cores" cpu.
This is Intel answer for the Ryzen 4950x and 3950x with real 16 cores in order not to look like they don't have an answer for 3 years.
Intel marketing misleading people to think they have 16 cores cpu with their smartphone level of cores.
Yeah I doubt that the size is the reason,I think it's more like how they removed and then added back HTT just to make the next gen more worth it as an upgrade.They were designed for 10nm but are getting back ported to 14nm so we are only getting 8 cores while current Comet Lake has 10 cores.
Lol I think Intel knows on their 10nm problems for years now... it is pushed 6+++++ months for 4 years and they pushed it in another 6 months because Alder Lake was supposed to come in 1h 2021 not 2nd half.These CPU's aren't supposed to hit the market for another year and have been in the design phase for a while. So unless Intel was certain there would be yield issues years in advance when they decided to choose this design, it's unlikely the reason. Alder Lake is supposed to use Golden Cove cores which according to Jim Keller are "significantly bigger" than Sunny Cove cores. This in conjunction with Golden Cove originally being designed for 7nm, and getting back ported to 10nm for Alder Lake likely has more to do with why Intel is going with big-little.
Same thing appears to be happening with Rocket Lake. It's reportedly using Tiger Lake cores, the successor to Sunny Cove which are 38% larger than Coffee Lake cores. They were designed for 10nm but are getting back ported to 14nm so we are only getting 8 cores while current Comet Lake has 10 cores.
It's not just size, it's power and heat as well. Intel is already pushing the mainstream boundaries of both with the 10900K. Add 38% more transistors to each core and you're not doing the engineering team any favors.Yeah I doubt that the size is the reason,I think it's more like how they removed and then added back HTT just to make the next gen more worth it as an upgrade.
Eh it's AVX that is pushing both not the actual cores/instructions and having a larger surface on the chip can only help with cooling.It's not just size, it's power and heat as well. Intel is already pushing the mainstream boundaries of both with the 10900K. Add 38% more transistors to each core and you're not doing the engineering team any favors.
