First time poster, long time lurker. I recently built my stem from the ground up and this has been my first build. Amazingly everything went 100% smoothly. Well I decided to watch my temps because I had heard that the Intel stock fans for the Core 2 Duo's aren't the greatest. I ran a torture test using Prime95 with only 2 threads and my temps jumped up outrageously. I went ahead and decided to remove the cooler, clean the thermal paste off of it and the cpu reapply a pea sized portion, and make sure the push pins seated properly. Still the same thing. Below are screen shots of the temps. I'd like to play AION tomorrow night, but I'm scared to run the CPU if it's going to go to that high of a temp.
I'm using an NZXT M59 case. My side fan pulls air INTO the case, my rear fan pulls air out. Cpu fan pulls air ONTO the heatsink.
Ambient room temperature is roughly 73 F
Next Thursday I'm picking up an aftermarket cooler, but I need a solution until then. Any help would be greatly appreciated.
