Intel Haswell Pentiums Good Enough For Basic Power-Efficient Multi-Monitor Work PC?
RevOne
144
Hoping someone may be kind enough to lend assistance/opinions with a quick build.
Looking at a basic, no-frills PC. No gaming. Occasional video streaming up to 1080p, 720p is fine.
Budget: $200 - $250 final (don't mind rebates)
Goals: Power efficiency, price, w/o sacrificing too much performance
Use: [Running simultaneously]
  • ■Chrome browser (+5 extensions, anywhere from 5 to 15 tabs open)
    ■+ running VPN service
    ■+ running IM messaging program.
    Spread across two monitors (1x 22" + 1x 19"; both @ 1366x768)
Have:
PSU: CORSAIR CS450M 450W 80+ Gold $30 after rebate
CASE: Rosewill FBM-01 Micro ATX $27
SSD: 120GB SanDisk SSD PLUS $40
Total price for all (after rebates/coupons): $87
Looking at/Need:
MOBO: GIGABYTE GA-H81M-HD2 LGA 1150 $32 after rebate
CPU: Intel Pentium Haswell @ 3.0GHz or more (G3220, G3258, etc.) - G3258 was $40 at Fry's recently, holding for similar sale. Willing to go as much as $60 perhaps
RAM: Good 1333MHz - 1600MHz Cas 7 or 8 Dual Channel 8GB (2x4GB) Kit w/ heatsinks $35 - $40 range
Connected via LAN (no WiFi adapter needed)
Storage requirements: .jpg/.png, .pdf, .docx, etc.
No optical drive needed
Aftermarket CPU fan/cooling not necessary
USB 3.0 not necessary.
Windows 10 ready a plus.
Hoping the Intel HD Graphics will be sufficient enough to drive those two monitors well enough for what I'm doing. Mouse, keyboard, cables, OS, etc. already covered.
Thanks in advance!
If all you need is effectively a basic office PC, then just about anything current-gen you can buy today should be good enough.
If you want a little more oomph though, you might want to at least consider the i3 - the two extra threads will help with system responsiveness if you start running more software concurrently.
