Intel ht tech problem
maurick
107
hi guyzzzz!
how u ol doin?
just want to ask u some questions about my i7 920
when i want to make a benchie, i want to activate intel ht (hyperthreading) but when i open real temp to check my temps,
i'm surpriced cause i only see 2 cores!!
the first time i activate ht it was 4 on real temp and 8 with prime95!
i tried to change ol settings from the bios, but i just cant understand y intel ht activates only 2 cores!
some1 got i7 920 have seen this kind of problem?
Hi, I'm peachy thanks, How're you?
Go into the BIOS and load default settings, Boot into windows, Open task manager, Go to the performance tab and you'll see 8 threads :)
Also you could download CPU-Z and that will tell you how many cores, and threads you have.
Go to the start menu and search for msconfig (or in XP, open Run... and type msconfig). Open it and go to the Boot tab. Clcik the Advanced options button and see if the "number of processors" option is checked. If it is, uncheck it and restart. If it's not checked, check it and select 8 processors from the drop-down. Restart and verify that you have 4 physical cores and 8 logical cores (threads) in CPU-Z.
