G
Guest
Guest
I just finishing building a new computer (my first time in years), and I'm worried that my CPU is running too hot. I've had it sitting in the BIOS screen now for about 30 minutes, and the CPU is currently running at 60 degrees celsius (140 farenheit).
One thing to note is that this computer is a micro-itx form factor... meaning that the case is about the size of a shoebox. The tower sits vertically (with rubber spacers on the bottom of the case) with an 80mm intake fan on the bottom, and an 80mm outtake fan on the top. There's no room for an exhaust fan on the back of the case.
Do you belive that my CPU is running too hot, given this setup? I used Arctic Silver 5 between th CPU and heatsink, but I'm worried that I may not have applied it as carefully as I thought. My real concern is, given that I haven't even installed Windows 7 yet (or a DVD drive for that matter), I'm afraid that once I do, the temperature will raise even higher.
Thoughts?
Thoughts?
