[SOLVED] Intel i5-10600k and BeQuiet Dark Rock Pro 4
Cem Goker
290
22
19,015
Hi guys, just wanna do a sanity check with the said CPU and cooler before I buy the cooler that will replace my AIO. I currently have an NZXT X73 cooling the CPU - bought it on March, built the PC on August. One month into the build and the pump makes sort of loud, constant ticking noises. I tried looking for solutions in this forums and applied them. While the noise did go away for a few hours, it came back again. Since I reside in the Philippines, RMAing the AIO will be a major setback for me as I can't really replace it with another AIO due to shortages here right now. However, I have looked into BeQuiet Dark Rock Pro 4 and would like to know if it can handle my CPU that is overclocked to 5 Ghz on single core and 4.7Ghz all core with a -1 AVX offset. Thank you very much in advance for any help!
Never look at idle I only judge under load. I can run OCCT to stress it and it's in the mid 70's.
It will very some depending on how much voltage you had to add for the overclock.
