RazerZ :
Seeking Solace :
RazerZ :
Um why would you go with an apu and external gpu?
Just based on reviews I've read, the APU is great to start off to a gaming system and gives the option to boost performance adding a gpu without having to go for the more expensive ones. I'm just experimenting here and stand to be corrected if you don't think it would work
Well you are somewhat right, but usually the purpose of the APU is to play without a graphics card at a reasonable price for starting out gamers. The athlox a4 750k is the exact same as that apu except it lacks the integrated graphics and its only $80.
Anyways I chose the 8320 and R9 270 because the performance is the best possible within the $800 budget.
Good to know and thanks for the feedback
I'm mostly just getting to grips with Intel in my learning about components and build compatibility but still eager to learn about AMD. Both manufacturers definitely have their attractions.
AMD generally do very well for a gaming build on a budget, and I've seen great builders here post systems for $4-500 so figured I'd try throwing in an APU with an external (slightly cheaper GPU) to see how it played out (feedback) from the more knowledgeable such as yourself.
As I said before, thank you again for the feedback
