Intel i7-3770k running very hot
sagartiru2006
4
Allright I got my rig yesterday and its running damn hot.
Config:
i7-3770k
GA-H77M-D3H
Vengeance 4GB DDR3 1600 RAM
NZXT Cabinet Source 210 Elite
Corsair VS650 PSU
Havent overclocked or anything. But played games for 15-20mins along with software installation and transfer and stuff at which the HDD ran at 100% Cpu was at 14-20% during that time but after about 1-2hrz of usage the temps shot to 96'C
I ordered a cooler master hyper 212 right away. Is there anything that can help to reduce temps.
No i am not going to remove the CPU IHS (too risky)
at first the fan control was normal ... i then changed it to 2.5 PWM / 'C
Any one who owns that motherboard can let me know any other settings or anything that need to be changed please let me know
sagartiru2006
4
okie thank you well i ordered one HSF already so it will be on itz way tmorrow ... will install and update you guyz about the same..
The rig is of a frnd and hez out now will come by tmorrow afternoon so till then cant say anything
sagartiru2006
4
Well i have built many rigs ... i dont think the hsf is installed incorrectly ... will update you....
i have a sunbeam core contact freezer on mine ... built about 20-30 pcz but as ppl say ...
"No1 is perfect" so will check tmorrow
sagartiru2006
4
Sorry forgot to update you guyz.
I went in and checked my installation and it was not at all wrong. It was perfect but still the temps were the prob.
So I went and installed the Hyper 212 and now the temps are stable 33'C at idle and about 40'C after using for 20-30mins
Thanks for all the advices guyz.
