Intel i7-6700k maximum voltage for *longevity*
DreddTrekkiter
Commendable
Feb 20, 2016
18
Morning all,
I'm going to be building a new PC soon with an i7-6700k and Corsair H55 water cooler. Naturally, I'm going to want to mess about with overclocking it (why else would you get a K?) so I decided to do some research in advance.
While doing this, I discovered that apparently as you boost the speed you have to boost the voltage. And as you boost the voltage further and further this reduces the life of the CPU. I've read that the generally agreed maximum safe voltage is 1.4-1.45 volts.
But, I was hoping you guys could tell me if there is a point at which the life of the CPU goes down drastically but stays under the 1.4 volts maximum limit.
I'm sorry if this is an easy question, I'm still very new to OCing. Also, I'm sorry if this is in the wrong section of the forum.
Cheers
For water cooling I would recommend 1.4VCore as a max.
For every CPU there is a point where it requires more voltage for just a 100mhz increase.
For example, my i5 6600k handles 4.1GHz at 1.16VCore, but then it requires 1.225VCore for 4.2GHz, and a whopping 1.325VCore for 4.5GHz.
Find the frequency where you need the least voltage and are happy with heat production.
Latest posts
