Processor: Intel i7 920
Stock Heat Sink.
Case: Thermaltake Element G Mid Tower Case @ http://www.tigerdirect.com/applications/SearchTools/item-details.asp?Sku=T925-1321
Case contains: 1x230mm fan, 2x200mm, 1x140mm
Mainboard: EVGA X58 SLI Classified Intel X58 Socket LGA1366
Ram: Corsair XMS3 6GB DDR3 Tri PC12800 1600MHz (3x2GB)
SSD: Hitachi 1TB Serial ATA HD 7200/32MB/SATA-3G
HDD: OCZ Vertex Series 120GB SATA 2
Power Supply: Kingwin Mach 1 700w ATX Modular
Video: Sapphire Radeon HD 5870 1GB PCIe DDR5 w/HDMI & DVI
Operating System: Windows 7 Premium
THIS SYSTEM IS NOT OVERCLOCKED IN ANY WAY.
Hey everyone,
I just built this system 2 days ago and right out of the box I started to test the temperatures of the processor with the stock heat sink and without overclocking at all. I have not adjusted the bios in any way so everything is running at the auto detected levels.
My idle temps are 46°c and max load is 79°c.
I've read a lot about the temps for these processors and people that are overclocking them with aftermarket coolers. I've seen people saying that they are getting idle temps of 25°-30° overclocked at 3.6Ghz and max load temps of 50-60°c.
I am reading that these chips run hot but have yet to see ANYONE saying they are running as hot as mine is. Even with the fact that I don't have an aftermarket heatsink on it, I would only expect it to drop the temperatures by 10°c maximum once i did add one, which doesn't leave much room for overclocking it (Yes, I'd like to overclock to 3.6Ghz).
So what I'm looking for is if you guys think I got a bunk processor or am I just crazy and missing something here?
I have the option to return it for an exchange at no cost.
Thanks for any help in advance.
Stock Heat Sink.
Hey everyone,
