Intel Management Engine Interface Driver: Fatal error during installation
Yazooman
19
Built my new PC today, and I was getting drivers for my motherboard (Gigabyte H110M S2H) from here: http://
I've installed all of them except the "Intel Management Engine Interface" Driver, which is being problematic.
When I reach the part where the driver is being installed, it abruptly ends and gives me the error message "The Setup program ended prematurely because of the following error: Fatal error during installation."
When I do some digging around Google, I can't find a solution. What do you guys think?
Personally I wouldn't worry about installing it at all, it's a security and management platform that has little use to the home user. Google it and decide but I believe there is also a BIOS setting that has to be enabled.
Sweet, thanks mate!
