intel P965 and E6600 CPU/Fan temps
fingerbib
6
Hi, can anyone tell at what avg CPU temp your fan automatically speeds up to max revs?
mine is at max revs from about 35C. is this normal?
thanks.
fingerbib
6
well that's the problem, it won't lower automatically as it should, after all, it's supposed to be a smart fan connector on my mother board (MSI P965 platinum).
so, i'm wondering do i need to shell out for a new case/fans that would cool it even more. i'm beginning to think the fan control on the MB is dodgy.
EDIT: It's ok, i've found the solution. there was a setting in bios that was disabled.
cheers.
