Intel(R) Ethernet Connection (2) I218-V stuck at 10.00 Mbps/Full Duplex
Inthecourt
I recently just built a new computer. My parts -
PCPartPicker part list: http://pcpartpicker.com/p/YTVnXL
Price breakdown by merchant: http://pcpartpicker.com/p/YTVnXL/by_merchant/
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($234.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ OutletPC)
Motherboard: ASRock Z97 PRO4 ATX LGA1150 Motherboard ($99.99 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($79.98 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 770 2GB WINDFORCE Video Card ($319.99 @ Newegg)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case ($79.99 @ Newegg)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply ($44.99 @ Newegg)
Total: $949.90
Generated by PCPartPicker 2014-09-05 11:53 EDT-0400
Now the mother board came with the Intel(R) Ethernet Connection (2) I218-V aka Intel Gigabyte LAN. On older LAN connections I get 100 mbps and a lot faster internet speeds. I have done diagnostics of the new LAN device only to get Link speed: 10Mbps. The link partner is not capable of higher speeds every single time of testing. I have tried changing the speed and duplex setting, which when I turn to 100 mbps/Full duplex or higher, it disconnects the internet device for good then I have to re-install the drivers to get it working again. I have update BIOS, drivers to the correct updates and still I have this issue. I know my router is fine and my Cat5 cable, just tested it on my laptop with a realtek LAN card and was getting 100 mbps. Either the ethernet connector is damaged or I am missing a setting.
Even though a different ethernet adapter is OK with that cable, I would try a different cable with your suspect interface. Marginal cable is still the most likely culprit.
Thanks a lot, I had spear cat5 downstairs, plugged it in, and behold 100 mbps. Thank you!!
