valeman2012 Distinguished Apr 10, 2012 1,272 11 19,315 Feb 10, 2017 #1 Why is "(2)" on the name? Intel(R) Ethernet Connection (2) I219-V <---
Phillip Corcoran Titan Moderator Sep 7, 2013 26,100 910 120,140 Feb 10, 2017 #2 Because you must have previously set up a LAN connection before on that Windows installation. Windows remembers the first one, so it calls your existing one "2". Upvote 0 Downvote
valeman2012 Distinguished Apr 10, 2012 1,272 11 19,315 Feb 10, 2017 #3 Fresh Installed...so i do not know how it got there. .The Intel Connection 1219-V Network Adapter comes from Asrock Pro4 H270 ATX Motherboard. Upvote 0 Downvote
Phillip Corcoran Titan Moderator Sep 7, 2013 26,100 910 120,140 Feb 10, 2017 #4 Then may be you installed network driver twice? If everything working okay, just ignore it. Upvote 0 Downvote
valeman2012 Distinguished Apr 10, 2012 1,272 11 19,315 Mar 11, 2017 #5 Phillip Corcoran : Then may be you installed network driver twice? If everything working okay, just ignore it. How do i remove the (2) text. just to avoid confusion. Upvote 0 Downvote
M mhamdy Honorable Oct 18, 2013 8 0 10,520 Dec 26, 2017 #6 check this, it solved my problem: http://www.tomshardware.com/answers/id-3522088/intel-i219-refuses-establish-connection-disconnected.html Upvote 0 Downvote
