Question Intel Rapid Storage Technology Driver Issue
KingChangeIV
20
I was only able to find one post about this issue and I believe it was from sometime ago. So I was going through and checking on my motherboard updates and came across the one mentioned, now my computer will not display anything it’s been over 45 minutes I have shut it down by holding the power button. After shutting it down that way and boots back up and does the same thing, I cannot get to the BIOS, I cannot get to anything else other than a blank screen. Any thoughts on this?
It’s very frustrating because I knew that I probably shouldn’t install it and created a restore point previous to installing it but what can you do.
intel rapid storage tech is mainly used for raid, installing the driver shouldn't cause that issue
you could try resetting the CMOS battery, that should set bios to defaults and let you in
What motherbaord do you have?
Thermaltake Core V71 Extreme Full Tower Chassis
MSI PRO Z490-A PRO LGA 1200 Intel Z490 (MOBO)
Intel Core i7-10700K Comet Lake 8-Core 3.8 GHz (CPU)
EVGA GeForce GTX 1080 FTW DT GAMING ACX 3.0, 8GB GDDR5X (GPU)
EVGA SuperNOVA 1000 G2 120-G2-1000-XR 80+ GOLD (PSU)
CORSAIR Dominator Platinum RGB 32GB (2 x 16GB) DDR4 3200 (PC4 25600) Desktop Memory Model CMT32GX4M2C3200C16 (RAM)
NZXT Kraken X73 360mm (Cooler)
SAMSUNG 970 EVO Plus SSD 2TB - M.2 NVMe Interface Internal Solid State Drive with V-NAND Technology (MZ-V7S2T0B/AM) (Storage)
SAMSUNG 970 EVO PLUS M.2 2280 500GB (Storage) (OS)
Extra's
NZXT AC-HUEPS-M1, HUE+ Smart RGB Color Changing Digitally Controlled LED PC Lighting
HP OMEN - 27" IPS LED QHD FreeSync & G-Sync Compatible Gaming Monitor ( Main Monitor)
BenQ GW2765HT 27-Inch 2560x1440 IPS Monitor, 4ms (Secondary Monitor)
I guess I will have to figure that out because I left it on overnight and still no progress
