Question Intel SST Driver Problem
May 17, 2020
5
On my Dell XPS 13 (2019) running Windows 10 Home (18363) purchased in March, I began having a problem in May with a disappearing sound device. As long as I am running any audio program (YouTube, Groove Music, etc.), my sound works properly. When the music stops, within a few minutes, I will see a warning "No speakers or headphones are plugged in." and the speaker icon on the taskbar has a red X. When I check the Device Manager, the speakers have disappeared from the list of audio inputs and outputs, leaving only the Microphone Array. Further down the list, under System Devices, there is a yellow triangle next to the Intel Smart Sound Technology OED driver. Driver Properties reports Error 43, and notes: "FW Dump detected."
If I reboot, the sound is restored but fails again at a random time whether or not I am doing anything. I've also noticed that when I restart from the no sound device status, the computer restarts but the screen is blank. I have to do a hard restart to get the system working properly. If I do a restart before the device stops, it reboots without a problem.
In search of a solution, I have reinstalled the Intel driver, run System Mechanic, Driver Booster 7 (a driver updater program), and finally reset Windows. Both Dell and Intel's SystemAssist reports all drivers correct and up to date. After restoring Windows, I reinstalled Office 365 and Chrome without any extensions. The problem reappears.
I have looked at the Windows Event Log and notice several errors: "The program svchost.exe version 10.0.18362.1 stopped interacting with Windows and was closed." Source: "Application Hang." However, I don't know what that means.
Can anyone suggest a solution (other than to buy an Apple)?
Yes, don't do a "restore, refresh, reset" or any other "kind" of recovery or installation other than a CLEAN install. And in the future, it would be HIGHLY advisable to NEVER use programs like Driver booster. Get your drivers manually, directly from the product page for your motherboard or prebuilt system model.
Thank you for your prompt reply to my problem post. I followed the instructions in the link you posted and did not reinstall the Driver Booster program. I downloaded and installed the Win10 driver pack (1,400 items in CAB) from Dell. Sadly, the same problem as described in my OP reappeared.
Yeah, you didn't want the Win10 driver pack either. You want SPECIFIC drivers based on the EXACT model of the machine.
What is the EXACT express service tag number for your Dell? Should be listed on the device on a sticker.
The tag is 972D9Y2. When the problem reappeared, I went to the Dell support site and downloaded the Realtek HD Audio Driver (dated 02 Sep 2019). The download uninstalled the previous driver and installed the new one.
Shortly after, the sound device disappeared again.
For future reference, this SHOULD be the page for your system specific drivers. Dell tends to change URLs sometimes, dynamically, or not allow you to access a specific URL if you don't have their cookie on your browser so you may have to use your service tag number to get to the page, or not.
https://www.dell.com/support/home/e...g/0-a2Q3Zk9UZFUwVnFhWDVqN0RwV1F2dz090/drivers
I would recommend you install all of the following.
Chipset driver: https://dl.dell.com/FOLDER05664480M...Software_9NNTR_WIN_10.1.18019.8144_A08_03.EXE
This is the most recent Realtek driver listed FOR your product.
Important Information: This audio driver requires the Waves MaxxAudio Pro application that is installed to have full functionality. Waves MaxxAudio Pro is now a separate application that must be downloaded and installed from the Microsoft Store. This package that links to the Microsoft Store application is provided on support.Dell.com under the Drivers and Downloads Audio category.
Realtek driver: https://dl.dell.com/FOLDER05812787M...ion-Audio-Driver_DDRY2_WIN_6.0.8777.1_A02.EXE
MaxxAudio Pro application: https://dl.dell.com/FOLDER05532202M...o-Application_M85FF_WIN64_2.0.54.0_A03_06.EXE
There is further information in detail regarding Realtek audio drivers to be found here:
https://www.tenforums.com/sound-audio/125936-determine-hda-realtek-driver-needed-your-audio.html
Although I followed the links and downloaded Chipset and Realtek drivers, my problem reappeared. I read the tenforums page and noticed that I have none of the "special" files it refers to in, but cannot find them to add to the driver. I did find an older driver: 0009-64bit_Win7_Win8_Win81_Win10_R282 from the Realtek site and installed that one. It seems to be stable - but MaxAudioPro program doesn't work. The sound is lousy, but consistent.
Ok, so, there is another possibility. Your onboard sound is not working correctly because it is faulty. Is this system still under warranty? If so, I'd probably contact them and demand an RMA of the motherboard or whole system. If you purchased this new in March, you should not be having this, or any, problems.
Yeah, that does make things a bit more difficult. Both Saudi Arabia AND the current Covid 19 situation worldwide.
There is another option, but you probably won't like it much. You can always forego using the onboard sound and get a cheap third party soundcard, then disable the Realtek audio. A lot of people have had to do that on a number of boards from the last couple of generations because the fact is that the Realtek audio is not well supported and frankly, sucks.
