[SOLVED] Intel UHD 610 not running 60Hz @ 4K
Kayeye
78
I have an Asrock deskmini 310 with an G4920 CPU (Intel UHD 610 graphics). According to the specs, it will support 4K @ 60Hz using the Displayport. I bought a displayport to HDMI cable and I can't seem to get it past 30Hz. Is there a step I'm missing? All drivers are current.
After checking the box for the cable I bought, apparently it only supports 30hz. I was looking into it more and found some listings on amazon for adapters and cables which support 60hz. Based on the reviews, it looks like they work so I guess I'll give it a try.
Reactions: qataqo
