Question Intel uhd 630 wont run at max speed all the time in minecraft causing low fps.
remijado
5
Im running on intel uhd 630 for now while saving up for a graphics card and i have monitored the Intel uhd 630 clock speed in minecraft and it goes up to 1100Mhz and then goes down to 450 and causes lots of stuttering, so im asking if there is a way to force the intergrated grahpics to always run at max speed instead of fluctuating.
The game runs fine when its at 1100mhz but when the intel uhd 630 goes to 450mhz it starts dropping frames.
Looking for advice on how you can force the igpu to stay at 1100mhz.
If it helps my specs are here:
I3 10100, 16gb ddr4 2666mhz
Motherboard is a gigabyte b460m d3h.
Thanks.
