Hi
I have purchased a Mag Tomahawk X570 atx board (it isn’t here yet), the supplied WIFI/Bluetooth antenna are mounted directly to the boards rear IO.
As with our current (outgoing) computer, the antenna placement "might" be a problem for us because the computer sits in a corner under a large work table so there is the possibility the WIFI will be compromised by the obstacles between the transmitter and the computer. Our current setup has the WIFI antenna extended vertically about 1 meter which gives it line of sight to the transmitter.
Should we encounter issues with the new systems IO pannel antenna placement, is there a recommended - ideal antenna extension solution?
Thanks.
Thanks.
