killswitch-core :
I am a 3D character modeler, and I use Maya+Vray, Keyshot, and Modo which uses CPU extensively for rendering. The system will not operate 24/7 though. My budget for this build is $2000-2500 give or take. I will reuse my existing hardware from my current system so all I need within the budget are the following items:
Processors: 2x Intel Xeon 2630 V3
Cooler: 2x Corsair h80i GT
RAM: ?
Mainboard: ?
PSU: ?
Casing: ?
Here's the PCPartPicker link:
http://pcpartpicker.com/user/killswitch/saved/#view=KyBcCJ
I am having a hard time picking the right PSU, case, and the mainboard. Are mounting points for server boards different from desktop counterparts? I was hoping to reuse my existing ATX case from CoolerMaster, Exactly which board from Intel or Supermicro should I be looking at. I have almost always used Asus boards, and I am not familiar with Supermicro, but I hear good stuff regarding their boards.
killswitch-core,
The Xeon E5-2630 v3 (8-core @ 2.4/ 3.2Ghz) is a good performer. On Passmark Performance test, the average CPU score is 12718 for a single CPU Rated No. 41 and a dual CPU is 18807 and No. 32. For comparison a dual E5-2630 v2 (6-core @ 2.6 / 3.1) scores 16168 and is No 42. On a budget a good choice as you can model on 3.2GHz and render on the 2.4GHz plus it uses DDR4-2133 and has a wider memory bandwidth.
For a motherboard, I suggest:
Supermicro X10DAi or X10DA-0 Dual LGA2011/ Intel C612/ DDR4/ SATA3&USB3.0/ A&2GbE/ EATX Server Motherboard > $414
http://www.supermicro.com/products/motherboard/xeon/c600/x10dai.cfm
http://www.superbiiz.com/detail.php?name=MB-X10DAX
These have a very useful arrangement of PCIe x16 slots- good for an SLI
Another excellent motherboard with very high performance is the ASUS Z10PE-D16 WS:
ASUS Z10PE-D16 WS LGA2011-v3/ Intel C612 PCH/ DDR4/ Quad CrossFireX & 3-Way SLI/ SATA3&USB3.0/ M.2/ A&V&2GbE/ EEB Server Motherboard > $490
http://www.superbiiz.com/detail.php?name=MB-10P16WS
or >
ASUS Z10PE-D8 WS LGA2011-v3/ Intel C612 PCH/ DDR4/ 4-Way CrossFireX & 4-Way SLI/ SATA3&USB3.0/ M.2&SATA Express/ A&V&2GbE/ EEB Server Motherboard > $540
http://www.superbiiz.com/detail.php?name=MB-10PD8WS
>expensive and EEB size but the important feature here is an M.2 slot- I'm convinced PCIe SSD's and espeically those with doubled lanes like M.2 are the future for workstations.
On Passmark, a Dual E5-2630 v3 / ASUS Z10PE-D8 WS /64GB RAM /TItan X RAID 0 - probably a pair of 500GB+ SSDs:
Rating = 5565 / CPU=
21464 / 2D=818 / 3D = 10648 / Memory = 2227 Disk = 5466
A dual E5-2630 v3 / Supermicro X10DAi / 64GB RAM / Quadro K4200
Rating = 4876 / CPU=
20408 / 2D=712 / 3D = 4495 / Memory = 2129 Disk = 5725
The ASUS WS series does manage very good CPU performance
Another very good workstation board is the Intel S2600CW (SS-EEB) > $490, producing 20733 from a pair of the 2630's:
http://ark.intel.com/products/83027/Intel-Server-Board-S2600CW2
Intel DBS2600CW2 Dual LGA2011-v3/ Intel C610/ DDR4/ SATA3&USB3.0/ M.2/ V&2GbE/ SSI EEB Server Motherboard
> and I think that Intel boards are the highest quality construction of any with Supermicro second and ASUS very close. It's a pity that Intel is said to be easing out of the motherboard market as they are excellent quality.
RAM: Memory: 32GB (4x 8GB) Samsung DDR4-2133 8GB/1Gx72 ECC/REG CL15 Server Memory > $436 ($109ea.)
http://www.superbiiz.com/detail.php?name=D4218G4S1
I use 32GB in my main system not particularly that I have large files, but that I run so many simultantous large programs: AutoCad / Revit / Solidworks / Sketchup / Adobe CS / multiple browsers. I am currently learning Maya and can see that the files ican be immense, becuase of the all the polygons in textures nad I think running the viewports takes RAM as well. If you're having a dual CPU system, I see it it as, in effect having 16GB per CPU. It doesn't really work in that way, but is scalar to the overall system potential.
Case: Many dual CPU motherboards are E-ATX and actually I prefre it to have plenty of room for the RAM slots ot clear the CPU coolers- which can be larger, and more RAM slots- the Supermicro X10 has 16.
One approach I think might make a lot of sense for your system is to buy Supermicro Superworkstation:
Case /Motherboard /Power supply : Supermicro SuperWorkstation SYS-7038A-I Dual LGA2011 / Suprmicro X10DA / 900W Mid-Tower Workstation Barebone System (Black) > $663
http://www.supermicro.com/products/system/tower/7038/SYS-7038A-i.cfm
http://www.superbiiz.com/detail.php?name=SY-7038AI
This is barebones systems - with an X10DA motherboard, CPU coolers, and a 900w PSU-and these are server quality for continuous running, so you only need to plug in the CPU's RAM, GPU, and drives. This is much easier and faster than researching, ordering, assembling and then shifting parts from the old system. The cooling is also worked out and these are said to be very quiet. In this way, you can keep the old system working even while you're testing the new system. Then selling the old system can fund a better GPU. On the subject of GPU's, I believe it is quite important to be able to use Quadro drivers to support the viewports and higher anti-aliasing in Maya. If you look at Autodesk certified GPU's for MAYA:
http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534&results=1&stype=graphic&product_group=19&release=2015&os=8192&manuf=all&opt=2
> only the GTX 690 and Titan are on the list from the desktop /gaming world- all the rest are Quadros and Firepros.
For awhile I used special Solidworks drivers for all my visualization work (Quadro FX 4800) as I could run it at x128 anti-aliasing. Find a used K2200 for $320-350.
So:
2X Xeon E5-2630 v3 > $1240
Supermicro Superworkstation SYS-7038 > $663
32GB Samsung DDR4-2133 ECC > $436
Quadro K2200 (used) $325
___________________________________
TOTAL = $2664
It useful to compare this idea if buying all the parts separately:
Supermicro X10DAX-O Dual LGA2011/ Intel C612/ DDR4/ SATA3&USB3.0/ A&2GbE/ EATX Server Motherboard > $415
2X Noctua NH-D14 120mm & 140mm SSO CPU Cooler $152 ($77 Each)
SeaSonic X Series X-850 (SS-850KM3 Active PFC F3) 850W ATX12V v2.3 / EPS 12V v2.91 SLI Ready CrossFire ___Ready 80 PLUS GOLD > $175
LIAN LI PC-A76WX Black Aluminum ATX Full Tower Computer Case > $220
_____________________________________
TOTAL = $2963
So the barebones solution with the same specification saves costs and time.
You're adding quite a few hours to your working time during the transition by no having to order and assemble every part, plus having the fast, continuous use switch-over plus you recover something from the used system sale.
Sorry- very long post!
Cheers,
BambiBoom
1. HP z420 (2015) > Xeon E5-1660 v2 six-core @ 3.7 / 4.0GHz > 32GB DDR3 ECC 1866 RAM > Quadro K4200 (4GB) > Intel 730 480GB (9SSDSC2BP480G4R5) > Western Digital Black WD1003FZEX 1TB> M-Audio 192 sound card > 600W PSU> Logitech z2300 > Linksys AE3000 USB WiFi > 2X Dell Ultrasharp U2715H (2560 X 1440) > Windows 7 Professional 64 >
[ Passmark Rating = 5064 > CPU= 13989 / 2D= 819 / 3D= 4596 / Mem= 2772 / Disk= 4555] [Cinebench R15 > CPU = 1014 OpenGL= 126.59 FPS] 7.8.15
Pending upgrade: HP /LSI 9212-4i PCIe SAS /SATA HBA RAID controller, 2X Seagate Constellation ES.3 1TB (RAID 1)
2. Dell Precision T5500 (2011) > Xeon X5680 six -core @ 3.33 / 3.6GHz, 24GB DDR3 ECC 1333 > Quadro K2200 (4GB ) > Samsung 840 250GB / WD RE4 Enterprise 1TB > M-Audio 192 sound card > Linksys WMP600N PCI WiFi > 875W PSU > Windows 7 Professional 64> HP 2711x (1920 X 1080)
[ Passmark system rating = 3490 / CPU = 9178 / 2D= 685 / 3D= 3566 / Mem= 1865 / Disk= 2122] [Cinebench 15 > CPU = 772 OpenGL= 99.72 FPS] 7.8.15
Pending upgrade: PERC H310 PCIe SAS /SATA RAID controller, 2X WD Black 1TB (RAID 1)(Converts disk system from 3GB/s to 6GB/s)
