Intense BSOD's please help!!!
cbeermann
51
I have been getting these for the last couple of days now and I am unable to figure out the problem here. They are happening mostly randomly, but I have noticed that it happens under load while im in game or trying to show screens on skype or anything with my second monitor. I am in SLI but idk what the issue is.
Dump File : 042512-14913-01.dmp
Crash Time : 4/25/2012 5:15:47 PM
Bug Check String : PFN_LIST_CORRUPT
Bug Check Code : 0x0000004e
Parameter 1 : 00000000`00000099
Parameter 2 : 00000000`00059e37
Parameter 3 : 00000000`00000003
Parameter 4 : 00000000`003485ef
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+7cc40
File Description : NT Kernel & System
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7601.17640 (win7sp1_gdr.110622-1506)
Processor : x64
Crash Address : ntoskrnl.exe+7cc40
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\042512-14913-01.dmp
Processors Count : 8
Major Version : 15
Minor Version : 7601
Dump File Size : 293,240
Dump File : 042512-17550-01.dmp
Crash Time : 4/25/2012 3:52:49 PM
Bug Check String : MEMORY_MANAGEMENT
Bug Check Code : 0x0000001a
Parameter 1 : 00000000`00000403
Parameter 2 : fffff680`000b1158
Parameter 3 : a3200000`7893a867
Parameter 4 : fffff680`000b1558
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\042512-17550-01.dmp
Major Version : 15
Dump File Size : 293,176
Dump File : 042512-41262-01.dmp
Crash Time : 4/25/2012 3:15:04 PM
Bug Check String : DRIVER_VERIFIER_DETECTED_VIOLATION
Bug Check Code : 0x000000c4
Parameter 1 : 00000000`00000000
Parameter 2 : 00000000`00000000
Parameter 3 : 00000000`00000000
Parameter 4 : 00000000`00000000
Caused By Driver : tcpipreg.sys
Caused By Address : tcpipreg.sys+35a5
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\042512-41262-01.dmp
Major Version : 15
Dump File Size : 293,112
Dump File : 042512-19749-01.dmp
Crash Time : 4/25/2012 12:27:02 AM
Caused By Address : tcpipreg.sys+abd0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\042512-19749-01.dmp
Major Version : 15
Dump File : 042512-20638-01.dmp
Crash Time : 4/25/2012 12:25:47 AM
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\042512-20638-01.dmp
Major Version : 15
Dump File : 042512-19858-01.dmp
Crash Time : 4/25/2012 12:24:21 AM
Bug Check String : PAGE_FAULT_IN_NONPAGED_AREA
Bug Check Code : 0x00000050
Parameter 1 : fffff880`0984f1f8
Parameter 3 : fffff800`036ff085
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\042512-19858-01.dmp
Major Version : 15
Dump File Size : 293,208
Dump File : 042412-15537-01.dmp
Crash Time : 4/24/2012 8:32:49 PM
Parameter 2 : 00000000`00005406
Parameter 4 : 00000000`00029286
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\042412-15537-01.dmp
Major Version : 15
Dump File Size : 293,248
Dump File : 042312-20451-01.dmp
Crash Time : 4/23/2012 2:00:47 AM
Parameter 1 : 00000000`00000002
Parameter 2 : 00000000`00298458
Parameter 3 : 00000000`0043f7ff
Parameter 4 : 00000000`00000001
Caused By Driver : fltmgr.sys
Caused By Address : fltmgr.sys+1b70
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\042312-20451-01.dmp
Major Version : 15
Intel(R) Core(TM) i7-2700K CPU @ 3.50GHz (8 CPUs), ~3.5GHz
2 x SLI NVIDIA GeForce GTX 560 Ti
Corsair Vengence 16 GB kit at 1600 hz
ASUS P8 Z68-V Pro/GEN3
I have the motherboard on X.M.P. for the memory otherwise it wouldnt work
Memtest. I agree, but have you updated the BIOS to 3202?
http://ca.asus.com/en/Motherboards/Intel_Socket_1155/P8Z68V_PROGEN3/#download
other:
If that passes, do this:
- remove 8GB of RAM, and
- remove the second graphics card, and
- drop to STOCK CPU settings, and
- update your BIOS if needed
I'm saying do ALL of these things rather than one at a time. If you are stable after that then you can start adding things back one at a time.
I had TWO different BSOD's occur and both were fixed by BIOS updates.
BSOD#1 - was an issue with my SSD drive, and
BSOD#2 - was an issue with my RAM
*Some people accidentally overclock their RAM when they overclock their CPU's. If you increase the Baseclock for the CPU you may need to reduce the multipler for the RAM so it's back where it should be.
Okay had to hop on the ole' laptop. So i had memtest run with all 4 DIMMS full and after a couple hours it had over 680000 erors so now im going through each stick/DIMM to try to see if its the RAM or the mobo.
Another question however, I downloaded Memtest-86 v4.0a and the title of it on the top left is in red, is this version supposed to be in red or is this bad news?
