Interchange extended screens laptop and monitor
Letalis1
88
Hi guys,
I've got my computer monitor hooked up to my laptop, with the monitor to the right of the laptop, but to get the mouse from the laptop screen to the monitor I have to pull it to the left instead of to the right, which would've been more logical. Is there a way to change this? My laptop's screen is the primary display.
Thanks in advance,
Kind regards
In windows, go to screen resolution, click mouse on the left screen in the windows that opened, and drag it to the right, hit apply and you should be good to go
It should also be the same for Intel and Nvidia. So it's pretty easy.
Right click desktop, go to screen resolution, then drag the monitor to the correct position and click apply or OK.
