So quite a while back I ordered some DDR2 RAM sticks for my aging computer. I got the recommendation from a swedish hardware forum where a guy with the exact same mobo as me had bought and used these sticks. So I figured I'd be safe to go with the same ones as him (he linked me the ebay auction).
Unfortunately, my computer quite randomly closes browser windows with youtube videos or games. It seems to happen when I put the computer under a bit of pressure. When just browsing the web and stuff it is fine without any issues, at least when using only 2 of the new sticks I ordered.
I have 4 sticks of the newer type in total (16gb), but currently running only 2 of them (8gb), as it seems to not crash as often. Running Windows 7 64-bit.
I've been trying them out a few times in different slots and neither worked properly. I ran windows built in memtest and had no issues with the ones I tested.
These sticks aren't in the memory reference from the mobo provider as far as I know (in fact no samsung ones are), but since that other guy got them to work it might not be impossible as long as they're not defect?
I should also say:
I have been experiencing frequent issues with the screen and input freezing along with stuttering/slow-motioned audio for a few seconds to a minute or so each time before going back to normal. Also when booting up - before the splash screen shows, just when switching the computer on - the screen glitches with crackling colors for a few seconds and then continues booting up just fine without any issues. The gpu also seems to be overheating a bit sometimes (right now 60C in idle and 166rpm on the gpu fan). Here's a quick HWmonitor screenshot.
I figured at least the ram issues might have something to do with voltages/timings/bios settings or something along these lines, but I'm not great at this stuff. Looks like it should be timed 6-6-6-18 when looking at the sticker on the ram, but it says 5-6-6-18 in cpu-z. Or maybe there is some power deficiencies between the GPU and the ram somehow?
Before I installed these new ram sticks I never had these crashes per se in games or videos, "only" the graphical and freezing issues explained above. Which by the way I need to sort out eventually as well.
Maybe you guys can help me sherlock out what's going on here?
I should also say:
Motherboard (GA-MA790X-UD4)
Cpu
Motherboard manual
Motherboard memory reference doc direct link
Previous RAM (Corsair 4GB (2x2GB) XMS-2 8500C5)
New RAM with sticker
CPU-z with new RAM installed (img 1) (img 2) (img 3)
GPU (Sapphire Radeon R9 380 Nitro 4GB)
PSU (650W Corsair CMPSU-650TXEU)
