So I noticed last night that when my PC was turned off, I heard some fans spinning so I checked and saw 2 of the 3 fans on my EVGA FTW3 3070 were spinning. I eventually figured out that when I had the USB cable plugged in for the USB port on my Corsair K70 MK2 keyboard, the GPU fans would spin. I unplugged the cable, and they stopped. The fans do not spin at idle when my PC is on with the pass through cable plugged in. So I did some more testing, I plugged in my old K68 Corsair keyboard and the pass through cable did not make the GPU fans spin when my PC was off. I plug everything into the USB ports on the motherboard, this issue is not present with the K70 keyboard plugged into the front. I did clear CMOS which didn't change anything. Is it some wiring goof with the K70 or is it something else? Also, no other fans spin with this issue, only the GPU fans. And it happens with all USB ports in the back.
Running Windows 10 build 19042.1466
Bios is the latest one
Specs:
i7 8700k
ASRock Z370 Gaming K6
16GB Corsair RAM 2666Mhz
Samsung 850 Pro 256GB SSD
Seagate 2TB NVME
WD Blue 1TB Hard drive
EVGA FTW3 3070
Corsair RM750X 80+ Gold (202) Fully modular power supply
Specs:
i7 8700k
Seagate 2TB NVME
EVGA FTW3 3070
