Intermittent internet connection from a DSL broadband
poofpoof
The disconnection happens at least once or twice every two minutes. We at least know that this isn't the devices problem, as all other devices connected to the modem both wired and wireless are disconnected whenever the random disconnection occurs. We're assuming the problem is either lying on the hardware and cables itself, or the configuration from the modem. However we've replaced all the cables that can be replaced with new ones except for the cable provided by the ISP that connects to the mainline, if it helps.
I tend to use the Windows Network Diagnostics whenever this happens, the error results keep switching from "The connection between your access point, router, or cable modem and the internet is broken", from something about "The DNS server isn't responding".
Any advice are much appreciated. Should any additional information be needed, I'd be willing to provide more.
Here is my IP configuration taken from cmd ipconfig/all:
Windows IP Configuration
Host Name . . . . . . . . . . . . : Scyris-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : domain.name
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : domain.name
Description . . . . . . . . . . . : Killer e2200 Gigabit Ethernet Controller
Physical Address. . . . . . . . . : 4C-CC-6A-23-7B-EC
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::e196:dc46:6457:f2e6%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.3(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, December 05, 2017 5:35:46 PM
Lease Expires . . . . . . . . . . : Thursday, December 07, 2017 8:59:12 AM
Default Gateway . . . . . . . . . : fe80::213:33ff:fef1:5711%11
192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 239914090
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-21-B7-D2-EE-4C-CC-6A-23-7B-EC
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.domain.name:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
