I put together a computer about two years ago and I'm having a lot of trouble keeping it working as well as diagnosing what the issue is. It's always had problems crashing intermittently where I get a windows blue screen mentioning it's a memory issue.
Because the issues happen on and off I've worked on it several times, reseating the CPU, swapping RAM sticks out and replacing the mother board. I installed the below components with all the memory and it worked ok. When I turned it on however it would start and then shut off, almost like a breaker on the power supply tripped until I turned it on again and it would stay on. I used it last night, playing games and running several monitors and it worked great.
However when I got home from work and tried to turn it on from hibernating it shut off then it would start up but not reach the post stage before shutting off. The most common issue seems to be that any time the computer goes into sleep mode it will have trouble booting up, or not at all. When it got blue screens more frequently it usually occurred after it went to sleep.
I'm wondering if anything from my description jumps out at anyone. My next step is to get someone to help me test the power supply and try swapping out the graphics card. At this point I feel I'm way over my head as far as my knowledge of building computers goes.
Computer Build:
Memory:
G.SKILL Ripjaws V Series 64GB 288-Pin DDR4
https://www.newegg.com/Product/Product.aspx?Item=9SIACVB57X2991
Ballistix Sport LT 64GB (4 x 16GB) 288-Pin DDR4 SDRAM DDR4 2400
https://www.newegg.com/Product/Product.aspx?Item=N82E16820156116
CPU Cooler:
Cooler Master MasterLiquid Lite 240 AIO CPU Liquid Cooler
https://www.newegg.com/Product/Product.aspx?Item=N82E16835103252
Mother Board:
ASUS ROG STRIX X99
https://www.newegg.com/Product/Product.aspx?Item=N82E16813132973
CPU:
Intel Core i7-6800K Broadwell-E 6-Core 3.4 GHz LGA 2011-v3 140W BX80671I76800K
https://www.newegg.com/Product/Product.aspx?Item=N82E16819117649
Power Supply:
EVGA SuperNOVA 750 G2 220-G2-0750-XR 80+ GOLD 750W
https://www.newegg.com/Product/Product.aspx?Item=N82E16817438017
GPU:
EVGA GeForce GTX 1080 FTW DT GAMING ACX 3.0, 8GB GDDR5X
https://www.newegg.com/Product/Product.aspx?Item=N82E16814487252
Computer Build:
Memory:
CPU Cooler:
Mother Board:
ASUS ROG STRIX X99
CPU:
Power Supply:
GPU:
