[SOLVED] Intermittent monitor black out while using VR headset
Motornerve
Commendable
May 8, 2019
21
So I have a VR rig set up in the office that I work at, and it is designed for employees to use on their lunch break.
Currently it works for the person in the VR Rig (Vive), but the monitor that is set up so other employees can see what is going on in the game (the main display) goes black for 2 seconds (duration) every 10 seconds (interval).
Some additional info:
  • Restarting fixes the issue, until a VR program is opened.
  • Tried switching the monitor.
  • Tried switching the HDMI cables.
  • This used to happen ALL the time, even before the VR program was fired up, but the computer was factory reset and now it only occurs when the VR program is opened.
  • Occasionally BSODs when running the VR program.
Windows 10 (Up to date as of 5/8/19)
AMD Ryzen 5 1600 3.2 GHz
16GB RAM
Radeon RX Vega 8 GB (Driver current as of 2/19/19)
System Information
Time of this report: 5/8/2019, 14:24:31
Machine name: SEA-VR
Machine Id: {6A48602B-02BB-41DB-8625-EF770BF3449B}
Operating System: Windows 10 Pro for Workstations 64-bit (10.0, Build 17134) (17134.rs4_release.180410-1804)
Language: English (Regional Setting: English)
System Manufacturer: Micro-Star International Co., Ltd.
System Model: MS-7A39
BIOS: 2.I0 (type: UEFI)
Processor: AMD Ryzen 5 1600 Six-Core Processor (12 CPUs), ~3.2GHz
Memory: 16384MB RAM
Available OS Memory: 16336MB RAM
Page File: 3592MB used, 15175MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.17134.0001 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Radeon RX Vega
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x687F)
DAC type: Internal DAC(400MHz)
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_1002&DEV_687F&SUBSYS_6B761002&REV_C3
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 16287 MB
Dedicated Memory: 8120 MB
Shared Memory: 8167 MB
Current Mode: 1920 x 1080 (32 bit) (32Hz)
HDR Support: Unknown
Display Topology: Unknown
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.000500,0.000500), Green(0.000500,0.000500), Blue(0.000500,0.000500), White Point(0.000500,0.000500)
Display Luminance: Min Luminance = 0.000000, Max Luminance = 0.000000, MaxFullFrameLuminance = 0.000000
Driver Name: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\aticfx64.dll,C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\aticfx64.dll,C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\aticfx64.dll,C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdxc64.dll
Driver File Version: 25.20.15025.1002 (English)
Driver Version: 25.20.15025.1002
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.4
Graphics Preemption: Primitive
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: No Blocks
Catalog Attributes: Universal:False Declarative:False
Driver Attributes: Final Retail
Driver Date/Size: 2/19/2019 5:00:00 PM, 1959528 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B71EE2-2B3F-11CF-5870-C77178C2D435}
Vendor ID: 0x1002
Device ID: 0x687F
SubSys ID: 0x6B761002
Revision ID: 0x00C3
Driver Strong Name: oem11.inf:cb0ae41418d44bb9:ati2mtag_R7500DS:25.20.15025.1002😛ci\ven_1002&dev_687f&rev_c3
Rank Of Driver: 00D12000
Video Accel: Unknown
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeVC1_VLD DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC DXVA2_ModeHEVC_VLD_Main10
Deinterlace Caps: n/a
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Not Available
D3D Status: Enabled
AGP Status: Not Available
MPO MaxPlanes: 1
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
PanelFitter Caps: Not Supported
PanelFitter Stretch: Not Supported
Sound Devices
Description: Remote Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID:
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: {3.0.0.00000001}.{6C26BA7D-F0B2-4225-B422-8168C5261E45}
Driver Version: ()
WHQL Logo'd: No
Date and Size: , 0 bytes
Other Files:
Driver Provider:
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC52B
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub (USB 3.0)
| Vendor/Product ID: 0x1022, 0x145C
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 11/8/2018 19:49:37, 565048 bytes
+-+ USB Input Device
| | Vendor/Product ID: 0x413C, 0x2107
| | Matching Device ID: USB\Class_03&SubClass_01
| | Service: HidUsb
| | Driver: hidusb.sys, 4/11/2018 16:33:52, 42496 bytes
| | Driver: hidclass.sys, 4/11/2018 16:33:52, 173568 bytes
| | Driver: hidparse.sys, 3/6/2019 01:33:02, 46080 bytes
| +-+ HID Keyboard Device
| | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | Service: kbdhid
| | | Driver: kbdhid.sys, 4/11/2018 16:33:52, 40448 bytes
| | | Driver: kbdclass.sys, 4/11/2018 16:33:52, 63904 bytes
+-+ USB Composite Device
| | Matching Device ID: USB\COMPOSITE
| | Service: usbccgp
| | Driver: usbccgp.sys, 4/11/2018 16:33:52, 168864 bytes
| +-+ Logitech USB Input Device
| | | Matching Device ID: usb\vid_046d&pid_c52b&mi_00
| | | Service: HidUsb
| | | Driver: LogiLDA.DLL, 10/13/2016 22:55:24, 3942864 bytes
| | | Driver: LdaCx2.dll, 10/13/2016 22:55:18, 2468304 bytes
| | | Driver: msvcp110.dll, 10/13/2016 22:55:26, 670800 bytes
| | | Driver: msvcr110.dll, 10/13/2016 22:55:28, 838224 bytes
| | | Driver: vccorlib110.dll, 10/13/2016 22:55:30, 363616 bytes
| | | | Service: kbdhid
| | | Service: HidUsb
| | +-+ HID-compliant mouse
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 4/11/2018 16:33:52, 33280 bytes
| | | | Driver: mouclass.sys, 4/11/2018 16:33:52, 56728 bytes
| | Vendor/Product ID: 0x046D, 0xC077
| | Service: HidUsb
| | | Service: mouhid
Gameport Devices
PS/2 Devices
+ Remote Desktop Keyboard Device
| Matching Device ID: TS_INPT\TS_KBD
| Service: terminpt
| Driver: terminpt.sys, 4/12/2018 02:21:02, 37280 bytes
+ Remote Desktop Mouse Device
| Matching Device ID: TS_INPT\TS_MOU
| Service: terminpt
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 211.3 GB
Total Space: 261.7 GB
File System: NTFS
Model: Crucial_CT275MX300SSD1
Drive: E:
Free Space: 3679.6 GB
Total Space: 3815.4 GB
File System: NTFS
Model: ST4000DM005-2DP166
System Devices
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1461&SUBSYS_00000000&REV_00\3&11583659&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1464&SUBSYS_00000000&REV_00\3&11583659&0&C4
Driver: n/a
Device ID: PCI\VEN_1022&DEV_790B&SUBSYS_7A391462&REV_59\3&11583659&0&A0
Driver: n/a
Name: AMD USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
Device ID: PCI\VEN_1022&DEV_145C&SUBSYS_7A391462&REV_00\4&C93BEE2&0&0339
Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.17134.0001 (English), 4/11/2018 16:33:52, 434592 bytes
Driver: C:\Windows\system32\DRIVERS\UMDF\UsbXhciCompanion.dll, 10.00.17134.0001 (English), 4/11/2018 16:33:52, 123576 bytes
Name: AMD PSP 3.0 Device
Device ID: PCI\VEN_1022&DEV_1456&SUBSYS_14561022&REV_00\4&C93BEE2&0&0239
Driver: C:\Windows\system32\DRIVERS\amdpsp.sys, 4.04.0000.0000 (English), 6/12/2017 06:07:22, 239976 bytes
Driver: C:\Windows\system32\DRIVERS\amdkmcsp.sys, 4.04.0000.0000 (English), 6/12/2017 06:07:20, 95080 bytes
Driver: C:\Windows\system32\amdumcsp.dll, 4.04.0000.0000 (English), 6/12/2017 06:07:24, 87536 bytes
Driver: C:\Windows\SysWOW64\amdumcsp.dll, 4.04.0000.0000 (English), 6/12/2017 06:07:22, 71152 bytes
Driver: C:\Windows\system32\t-base_client_api.dll, 4.04.0000.0000 (English), 6/12/2017 06:07:24, 26096 bytes
Driver: C:\Windows\SysWOW64\t-base_client_api.dll, 4.04.0000.0000 (English), 6/12/2017 06:07:24, 22000 bytes
Driver: C:\Windows\system32\tbaseregistry64.dll, 4.04.0000.0000 (English), 6/12/2017 06:07:26, 129008 bytes
Driver: C:\Windows\SysWOW64\tbaseregistry32.dll, 4.04.0000.0000 (English), 6/12/2017 06:07:26, 108528 bytes
Driver: C:\Windows\system32\WdfCoInstaller01011.dll, 1.11.9200.16384 (English), 6/12/2017 06:07:26, 1804672 bytes
Driver: C:\Windows\system32\pspcoins.dll, 1.00.0005.0009 (English), 6/12/2017 06:07:24, 106480 bytes
Name: High Definition Audio Bus
Device ID: PCI\VEN_1002&DEV_AAF8&SUBSYS_AAF81002&REV_00\6&2CBC9480&0&01000019
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.17134.0001 (English), 4/11/2018 16:33:45, 86016 bytes
Driver: C:\Windows\system32\DRIVERS\drmk.sys, 10.00.17134.0001 (English), 4/11/2018 16:33:46, 98304 bytes
Driver: C:\Windows\system32\DRIVERS\portcls.sys, 10.00.17134.0001 (English), 4/11/2018 16:33:46, 379392 bytes
Device ID: PCI\VEN_1022&DEV_1467&SUBSYS_00000000&REV_00\3&11583659&0&C7
Driver: n/a
Name: PCI Express Root Port
Device ID: PCI\VEN_1022&DEV_1453&SUBSYS_14531022&REV_00\3&11583659&0&19
Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.17134.0677 (English), 3/14/2019 01:56:59, 375096 bytes
Device ID: PCI\VEN_1022&DEV_1453&SUBSYS_14531022&REV_00\3&11583659&0&0B
Name: PCI Express Upstream Switch Port
Device ID: PCI\VEN_1022&DEV_43B2&SUBSYS_02011B21&REV_02\4&288C77C7&0&020B
Device ID: PCI\VEN_1022&DEV_1462&SUBSYS_00000000&REV_00\3&11583659&0&C2
Driver: n/a
Name: Radeon RX Vega
Device ID: PCI\VEN_1002&DEV_687F&SUBSYS_6B761002&REV_C3\6&2CBC9480&0&00000019
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atiesrxx.exe, 25.20.15025.1002 (English), 2/25/2019 04:57:44, 509048 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atio6axx.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:48, 39776376 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atioglxx.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:48, 32477296 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atidxx32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:14, 14664400 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atidxx64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:16, 17486856 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ATIODCLI.exe, 25.20.15025.1002 (English), 2/25/2019 04:57:48, 76920 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ATIODE.exe, 25.20.15025.1002 (English), 2/25/2019 04:57:48, 358520 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atig6pxx.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:44, 169080 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atig6txx.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:44, 240248 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atigktxx.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:44, 211568 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atiglpxx.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:44, 144504 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atikmpag.sys, 25.20.15025.1002 (English), 2/25/2019 04:57:46, 590968 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atiu9p64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:18, 202016 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atiu9pag.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:18, 166184 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atiuxp64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:22, 218104 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atiuxpag.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:22, 183776 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\coinst_18.50.dll, 1.00.0005.0009 (English), 2/25/2019 04:57:52, 1587616 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\aticfx32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:14, 1596240 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\aticfx64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:14, 1959528 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdocl.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:32, 46305904 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdocl64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:34, 56433272 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdhdl32.dll, 2/25/2019 04:57:08, 340824 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdhdl64.dll, 2/25/2019 04:57:08, 425032 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdmantle32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:30, 13341816 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdmantle64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:30, 15770744 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ativce03.dat, 12/4/2018 11:53:40, 160768 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ativvaxy_vi.dat, 9/18/2018 13:44:44, 324804 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ativvaxy_vi_nd.dat, 1/24/2019 13:46:04, 324672 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ativvaxy_cz_nd.dat, 1/22/2019 16:58:26, 272288 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amde31a.dat, 12/4/2018 12:40:26, 159072 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ativvaxy_FJ.dat, 9/18/2018 13:46:14, 267732 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ativvaxy_FJ_nd.dat, 1/24/2019 13:43:36, 267472 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdxc32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:12, 19027440 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdxc64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:12, 22218368 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdocl12cl.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:34, 21255288 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdocl12cl64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:34, 26486392 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdicdxx.dat, 2/11/2019 00:07:10, 1059299 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atiicdxx.dat, 11/6/2014 03:53:26, 737410 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ativvaxy_el_nd.dat, 1/22/2019 15:03:14, 374560 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdvlk32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:34, 14913144 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdvlk64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:36, 17211016 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amd-vulkan32.json, 12/17/2018 07:08:16, 701 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amd-vulkan64.json, 12/17/2018 07:08:10, 701 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amde34a.dat, 12/21/2018 08:06:04, 166560 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ativvaxy_stn_nd.dat, 1/22/2019 17:03:36, 277920 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amde34b.dat, 12/21/2018 08:06:08, 166560 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amduve32.dll, 17.00.0006.0000 (English), 2/25/2019 04:57:10, 144984 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amduve64.dll, 17.00.0006.0000 (English), 2/25/2019 04:57:10, 167352 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdmmcl.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:32, 126584 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdmmcl6.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:32, 148592 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atikmdag.sys, 25.20.15025.1002 (English), 2/25/2019 04:57:46, 52881528 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atiumd64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:18, 13863312 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atiumd6a.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:20, 13010368 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atiumdag.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:20, 11169640 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\atiumdva.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:20, 12369312 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ativce02.dat, 12/21/2018 08:06:06, 100832 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ativvaxy_cik.dat, 10/9/2018 13:58:04, 234292 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ativvaxy_cik_nd.dat, 1/24/2019 13:48:10, 234032 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ativvaxy_gl_nd.dat, 1/28/2019 15:16:02, 377280 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amde40a.dat, 12/21/2018 08:06:00, 173344 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ativvaxy_rv.dat, 1/22/2019 15:03:02, 348832 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdave32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:04, 118872 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdave64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:06, 133960 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ativvaxy_vg20.dat, 9/13/2018 09:33:42, 379200 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\ativvaxy_vg20_nd.dat, 1/28/2019 15:18:02, 380000 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\c0339583.inf_amd64_c5be1e62234928ae\B339442\amdefctb.dat, 3/27/2018 08:56:50, 281096 bytes
Driver: C:\Windows\system32\atieclxx.exe, 25.20.15025.1002 (English), 2/25/2019 04:57:42, 759408 bytes
Driver: C:\Windows\system32\atidemgy.dll, 4.05.6990.33686 (English), 2/25/2019 04:57:42, 468080 bytes
Driver: C:\Windows\system32\ati2erec.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:40, 69752 bytes
Driver: C:\Windows\system32\atig6txx.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:44, 240248 bytes
Driver: C:\Windows\system32\atiapfxx.blb, 2/20/2019 16:39:48, 906872 bytes
Driver: C:\Windows\system32\OpenCL.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:36, 177784 bytes
Driver: C:\Windows\system32\clinfo.exe, 2/25/2019 04:57:52, 340896 bytes
Driver: C:\Windows\system32\amdhcp64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:08, 190088 bytes
Driver: C:\Windows\system32\kapp_ci.sbin, 1/10/2019 09:25:52, 125488 bytes
Driver: C:\Windows\system32\kapp_si.sbin, 1/10/2019 08:17:56, 121168 bytes
Driver: C:\Windows\system32\samu_krnl_ci.sbin, 10/13/2017 11:01:56, 154384 bytes
Driver: C:\Windows\system32\samu_krnl_isv_ci.sbin, 10/13/2017 11:01:56, 138832 bytes
Driver: C:\Windows\system32\mantle64.dll, 25.20.15025.1002 (English), 2/25/2019 04:58:00, 183712 bytes
Driver: C:\Windows\system32\mantleaxl64.dll, 25.20.15025.1002 (English), 2/25/2019 04:58:00, 162720 bytes
Driver: C:\Windows\system32\amdgfxinfo64.dll, 2/25/2019 04:57:28, 474232 bytes
Driver: C:\Windows\system32\atieah64.exe, 2/25/2019 04:57:42, 439928 bytes
Driver: C:\Windows\system32\detoured.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:54, 19200 bytes
Driver: C:\Windows\system32\Rapidfire64.dll, 1.02.0001.0062 (English), 2/25/2019 04:58:04, 570784 bytes
Driver: C:\Windows\system32\RapidFireServer64.dll, 1.02.0000.0015 (English), 2/25/2019 04:58:04, 45984 bytes
Driver: C:\Windows\system32\amdlvr64.dll, 1.00.0015.0000 (English), 2/25/2019 04:57:30, 922744 bytes
Driver: C:\Windows\system32\GameManager64.dll, 2/25/2019 04:57:58, 480160 bytes
Driver: C:\Windows\system32\amdmiracast.dll, 2/25/2019 04:57:10, 546880 bytes
Driver: C:\Windows\system32\dgtrayicon.exe, 2/25/2019 04:57:54, 492448 bytes
Driver: C:\Windows\system32\AMDKernelEvents.man, 2/21/2018 09:09:56, 34450 bytes
Driver: C:\Windows\system32\amfrt64.dll, 1.04.0012.0000 (English), 2/25/2019 04:57:38, 3735688 bytes
Driver: C:\Windows\system32\amdmcl64.dll, 1.06.0000.0000 (English), 2/25/2019 04:57:32, 553080 bytes
Driver: C:\Windows\system32\amdxc64.dll, 8.18.0010.0296 (English), 2/25/2019 04:57:36, 119928 bytes
Driver: C:\Windows\system32\aticfx64.dll, 8.17.0010.1653 (English), 2/25/2019 04:57:40, 169272 bytes
Driver: C:\Windows\system32\atidxx64.dll, 2/25/2019 04:57:42, 123504 bytes
Driver: C:\Windows\system32\atimpc64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:18, 127544 bytes
Driver: C:\Windows\system32\atimuixx.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:46, 125040 bytes
Driver: C:\Windows\system32\atisamu64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:50, 158840 bytes
Driver: C:\Windows\system32\atiumd6a.cap, 2/20/2019 13:27:54, 3437632 bytes
Driver: C:\Windows\system32\ativvsva.dat, 10/13/2017 11:01:54, 157144 bytes
Driver: C:\Windows\system32\ativvsvl.dat, 10/13/2017 11:01:54, 204952 bytes
Driver: C:\Windows\system32\amdave64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:06, 133960 bytes
Driver: C:\Windows\system32\amdpcom64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:10, 127760 bytes
Driver: C:\Windows\system32\atiadlxx.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:40, 1664112 bytes
Driver: C:\Windows\SysWOW64\atigktxx.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:44, 211568 bytes
Driver: C:\Windows\SysWOW64\atiapfxx.blb, 2/20/2019 16:39:48, 906872 bytes
Driver: C:\Windows\SysWOW64\OpenCL.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:36, 154232 bytes
Driver: C:\Windows\SysWOW64\amdhcp32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:08, 167208 bytes
Driver: C:\Windows\SysWOW64\mantle32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:58, 151968 bytes
Driver: C:\Windows\SysWOW64\mantleaxl32.dll, 25.20.15025.1002 (English), 2/25/2019 04:58:00, 137632 bytes
Driver: C:\Windows\SysWOW64\amdgfxinfo32.dll, 2/25/2019 04:57:26, 382584 bytes
Driver: C:\Windows\SysWOW64\atieah32.exe, 2/25/2019 04:57:42, 353400 bytes
Driver: C:\Windows\SysWOW64\detoured.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:54, 19200 bytes
Driver: C:\Windows\SysWOW64\RapidFireServer.dll, 1.02.0000.0015 (English), 2/25/2019 04:58:04, 42912 bytes
Driver: C:\Windows\SysWOW64\Rapidfire.dll, 1.02.0001.0062 (English), 2/25/2019 04:58:04, 481696 bytes
Driver: C:\Windows\SysWOW64\amdlvr32.dll, 1.00.0015.0000 (English), 2/25/2019 04:57:28, 752760 bytes
Driver: C:\Windows\SysWOW64\GameManager32.dll, 2/25/2019 04:57:58, 382368 bytes
Driver: C:\Windows\SysWOW64\amfrt32.dll, 1.04.0012.0000 (English), 2/25/2019 04:57:38, 3363960 bytes
Driver: C:\Windows\SysWOW64\amdmcl32.dll, 1.06.0000.0000 (English), 2/25/2019 04:57:30, 383112 bytes
Driver: C:\Windows\SysWOW64\amdxc32.dll, 8.18.0010.0296 (English), 2/25/2019 04:57:36, 105080 bytes
Driver: C:\Windows\SysWOW64\aticfx32.dll, 8.17.0010.1653 (English), 2/25/2019 04:57:40, 148120 bytes
Driver: C:\Windows\SysWOW64\atidxx32.dll, 2/25/2019 04:57:42, 106104 bytes
Driver: C:\Windows\SysWOW64\atimpc32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:16, 106856 bytes
Driver: C:\Windows\SysWOW64\atisamu32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:48, 135792 bytes
Driver: C:\Windows\SysWOW64\atiumdva.cap, 2/20/2019 13:27:56, 3471376 bytes
Driver: C:\Windows\SysWOW64\ativvsva.dat, 10/13/2017 11:01:54, 157144 bytes
Driver: C:\Windows\SysWOW64\ativvsvl.dat, 10/13/2017 11:01:54, 204952 bytes
Driver: C:\Windows\SysWOW64\amdave32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:04, 118872 bytes
Driver: C:\Windows\SysWOW64\amdpcom32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:10, 106856 bytes
Driver: C:\Windows\SysWOW64\atiadlxx.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:40, 1210488 bytes
Driver: C:\Windows\SysWOW64\atiadlxy.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:40, 1210488 bytes
Driver: C:\Program Files\Common Files\ATI Technologies\DOPPEngine.dll, 2/25/2019 04:57:56, 345504 bytes
Driver: C:\Program Files\Common Files\ATI Technologies\DSEManager.exe, 2/25/2019 04:57:56, 246176 bytes
Driver: C:\Program Files\AMD\CCC2\Install\ccc2_install.exe, 8.911.0003.3000 (English), 2/25/2019 04:57:52, 151858664 bytes
Driver: C:\Program Files\AMD\amdkmpfd\amdkmpfd.stz, 18.45.0001.0000 (English), 2/25/2019 04:57:28, 103456 bytes
Driver: C:\Program Files\AMD\amdkmpfd\amdkmpfd.itz, 1/25/2019 13:29:00, 1990 bytes
Driver: C:\Program Files\AMD\amdkmpfd\amdkmpfd.ctz, 1/25/2019 13:29:00, 8462 bytes
Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDh264Enc32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:06, 1442608 bytes
Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDh264Enc64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:06, 1651472 bytes
Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDhwDecoder_32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:28, 246896 bytes
Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDhwDecoder_64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:28, 300152 bytes
Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\amf-mft-mjpeg-decoder32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:12, 1364856 bytes
Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\amf-mft-mjpeg-decoder64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:14, 1685520 bytes
Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\mcl32.dll, 25.20.15025.1002 (English), 2/25/2019 04:58:02, 74656 bytes
Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\mcl64.dll, 25.20.15025.1002 (English), 2/25/2019 04:58:02, 90016 bytes
Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDh265Enc32.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:06, 916904 bytes
Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDh265Enc64.dll, 25.20.15025.1002 (English), 2/25/2019 04:57:08, 1163112 bytes
Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\amf-mft-decvp9-decoder32.dll, 1.00.0000.0000 (English), 2/25/2019 04:57:38, 14845560 bytes
Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\amf-mft-decvp9-decoder64.dll, 1.00.0000.0000 (English), 2/25/2019 04:57:38, 16408184 bytes
Driver: C:\Windows\system32\coinst_18.50.dll, 1.00.0005.0009 (English), 2/25/2019 04:57:52, 1587616 bytes
Device ID: PCI\VEN_1022&DEV_1465&SUBSYS_00000000&REV_00\3&11583659&0&C5
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1455&SUBSYS_14551022&REV_00\4&2B9CC193&0&0041
Driver: C:\Windows\system32\DRIVERS\AMDPCIDev.sys, 1.00.0000.0055 (English), 4/26/2018 00:51:24, 31592 bytes
Device ID: PCI\VEN_1022&DEV_1460&SUBSYS_00000000&REV_00\3&11583659&0&C0
Driver: n/a
Name: AMD USB 3.10 eXtensible Host Controller - 1.10 (Microsoft)
Device ID: PCI\VEN_1022&DEV_43BB&SUBSYS_11421B21&REV_02\4&288C77C7&0&000B
Device ID: PCI\VEN_1022&DEV_145A&SUBSYS_145A1022&REV_00\4&C93BEE2&0&0039
Name: Standard SATA AHCI Controller
Device ID: PCI\VEN_1022&DEV_43B7&SUBSYS_10621B21&REV_02\4&288C77C7&0&010B
Driver: C:\Windows\system32\DRIVERS\storahci.sys, 10.00.17134.0001 (English), 4/11/2018 16:33:49, 156056 bytes
Name: Realtek PCIe GbE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_7A391462&REV_15\01000000684CE00000
Driver: C:\Windows\system32\DRIVERS\rt640x64.sys, 10.31.0828.2018 (English), 8/30/2018 23:55:12, 1122200 bytes
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1022&DEV_790E&SUBSYS_7A391462&REV_51\3&11583659&0&A3
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.17134.0001 (English), 4/11/2018 16:33:49, 18848 bytes
Name: PCI Express Downstream Switch Port
Device ID: PCI\VEN_1022&DEV_43B4&SUBSYS_33061B21&REV_02\5&588F5BE&0&38020B
Device ID: PCI\VEN_1022&DEV_1463&SUBSYS_00000000&REV_00\3&11583659&0&C3
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_1022&DEV_1457&SUBSYS_FA391462&REV_00\4&2B9CC193&0&0341
Device ID: PCI\VEN_1022&DEV_1471&SUBSYS_14711022&REV_00\5&14DB8B86&0&000019
Device ID: PCI\VEN_1022&DEV_1454&SUBSYS_14541022&REV_00\3&11583659&0&41
Device ID: PCI\VEN_1022&DEV_1454&SUBSYS_14541022&REV_00\3&11583659&0&39
Device ID: PCI\VEN_1022&DEV_1470&SUBSYS_00000000&REV_C3\4&1C3D25BB&0&0019
Device ID: PCI\VEN_1022&DEV_1452&SUBSYS_00000000&REV_00\3&11583659&0&40
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1452&SUBSYS_00000000&REV_00\3&11583659&0&38
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1452&SUBSYS_00000000&REV_00\3&11583659&0&20
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1452&SUBSYS_00000000&REV_00\3&11583659&0&18
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1452&SUBSYS_00000000&REV_00\3&11583659&0&10
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1452&SUBSYS_00000000&REV_00\3&11583659&0&08
Driver: n/a
Device ID: PCI\VEN_1022&DEV_43B4&SUBSYS_33061B21&REV_02\5&588F5BE&0&28020B
Device ID: PCI\VEN_1022&DEV_1466&SUBSYS_00000000&REV_00\3&11583659&0&C6
Driver: n/a
Device ID: PCI\VEN_1022&DEV_7901&SUBSYS_7A391462&REV_51\4&2B9CC193&0&0241
Device ID: PCI\VEN_1022&DEV_43B4&SUBSYS_33061B21&REV_02\5&588F5BE&0&30020B
Device ID: PCI\VEN_1022&DEV_1450&SUBSYS_7A391462&REV_00\3&11583659&0&00
Driver: n/a
Device ID: PCI\VEN_1022&DEV_43B4&SUBSYS_33061B21&REV_02\5&588F5BE&0&20020B
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.17134.0001
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.17134.0001
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.17134.0001
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.17134.0001
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.17134.0001
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.17134.0001
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.17134.0471
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.17134.0001
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.17134.0001
DV Muxer,0x00400000,0,0,qdv.dll,10.00.17134.0001
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.17134.0001
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.17134.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.17134.0001
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.17134.0001
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.17134.0001
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.17134.0471
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.17134.0001
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.17134.0001
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.17134.0001
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.17134.0001
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.17134.0001
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.17134.0001
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.17134.0001
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.17134.0001
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.17134.0112
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.17134.0001
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.17134.0001
DV Splitter,0x00600000,1,2,qdv.dll,10.00.17134.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.17134.0001
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.17134.0112
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.17134.0001
Video Renderer,0x00800001,1,0,quartz.dll,10.00.17134.0001
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.17134.0001
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.17134.0001
Video Renderer,0x00400000,1,0,quartz.dll,10.00.17134.0001
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.17134.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.17134.0001
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.17134.0001
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.17134.0001
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.17134.0001
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.17134.0112
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.17134.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.17134.0001
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.17134.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.17134.0001
Null Renderer,0x00200000,1,0,qedit.dll,10.00.17134.0001
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.17134.0001
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.17134.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.17134.0001
Smart Tee,0x00200000,1,2,qcap.dll,10.00.17134.0001
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.17134.0001
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.17134.0001
Wave Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
File stream renderer,0x00400000,1,1,quartz.dll,10.00.17134.0001
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.17134.0471
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.17134.0001
AVI Mux,0x00200000,1,0,qcap.dll,10.00.17134.0001
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.17134.0001
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.17134.0001
File Source (URL),0x00400000,0,1,quartz.dll,10.00.17134.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.17134.0001
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.17134.0320
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.17134.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.17134.0001
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.17134.0001
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.17134.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.17134.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.17134.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.17134.0001
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.17134.0001
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.17134.0001
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.17134.0001
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.17134.0001
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.17134.0001
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.17134.0001
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.17134.0001
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.17134.0001
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.17134.0441
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.17134.0441
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.17134.0441
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.17134.0001
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.17134.0001
WDM Streaming Capture Devices:
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.17134.0001
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.17134.0001
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.17134.0001
WDM Streaming Communication Transforms:
Audio Renderers:
Remote Audio,0x00200000,1,0,quartz.dll,10.00.17134.0001
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.17134.0001
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.17134.0001
DirectSound: Remote Audio,0x00200000,1,0,quartz.dll,10.00.17134.0001
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
<transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
AMD D3D11 Hardware MFT Playback Decoder, {17796AEB-0F66-4663-B8FB-99CBEE0224CE}, 0x4, 8, AMDhwDecoder_64.dll, 25.20.15025.1002
AMD MFT MJPEG Decoder, {687CBC51-25DA-4FFC-A678-1E64943285A7}, 0x4, 8, amf-mft-mjpeg-decoder64.dll, 25.20.15025.1002
AMD MFT VP9 Sync Decoder, {2D2D728A-67D6-48AB-89FB-A6EC65554970}, 0x1, amf-mft-decvp9-decoder64.dll, 1.00.0000.0000
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.17134.0471
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.17134.0001
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.17134.0001
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.17134.0471
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.17134.0001
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.17134.0471
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.17134.0001
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.17134.0001
Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}, 0x1, MSVP9DEC.dll, 10.00.17134.0471
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.17134.0001
Video Encoders:
AMDh265Encoder, {5FD65104-A924-4835-AB71-09A223E3E37B}, 0x4, 8, AMDh265Enc64.dll, 25.20.15025.1002
AMDh264Encoder, {ADC9BC80-0F41-46C6-AB75-D693D793597D}, 0x4, 8, AMDh264Enc64.dll, 25.20.15025.1002
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.17134.0001
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.17134.0001
Microsoft MF VPX Encoder Transform, {AEB6C755-2546-4881-82CC-E15AE5EBFF3D}, 0x1, MSVPXENC.dll, 10.00.17134.0706
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.17134.0001
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.17134.0001
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.17134.0112
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.17134.0001
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.17134.0001
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.17134.0706
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.17134.0001
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.17134.0001
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.17134.0619
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.17134.0081
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.17134.0001
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.17134.0001
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.17134.0471
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.17134.0556
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.17134.0556
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.17134.0001
Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.17134.0001
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.17134.0001
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.17134.0471
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.17134.0001
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.17134.0556
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.17134.0556
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.17134.0001
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.17134.0001
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.17134.0556
Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.17134.0001
DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.17134.0001
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.17134.0001
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.17134.0556
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.17134.0001
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.17134.0001
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.17134.0001
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.17134.0112
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.17134.0001
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.17134.0001
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.17134.0001
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.17134.0001
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.17134.0001
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.17134.0137
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.17134.0407
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.17134.0471
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{30395056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
{30385056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket 2248002716033392536, type 5
Event Name: RADAR_PRE_LEAK_64
Response: Not available
Cab Id: 0
Problem signature:
P1: UE4Game-Win64-Shipping.exe
P2: 4.17.1.0
P3: 10.0.17134.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER1 +++:
Fault bucket 2140987185245414010, type 5
Cab Id: 0
Problem signature:
P1: EWVR.exe
P2: 5.6.4.62028
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER2 +++:
Fault bucket , type 0
Event Name: BlueScreen
Cab Id: 0
Problem signature:
P1: 34
P2: 12a5
P3: ffffffffc0000420
P4: 0
P5: 0
P6: 10_0_17134
P7: 0_0
P8: 256_1
P9:
P10:
+++ WER3 +++:
Cab Id: 0
Problem signature:
P1: 34
P2: 12a5
P4: 0
P5: 0
P6: 10_0_17134
P7: 0_0
P8: 256_1
P9:
P10:
+++ WER4 +++:
Fault bucket 2022323315360715972, type 5
Cab Id: 0
Problem signature:
P1: TiltBrush.exe
P2: 2017.4.11.27534
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER5 +++:
Fault bucket 1498139109136800185, type 5
Cab Id: 0
Problem signature:
P1: TheLab.exe
P2: 5.4.0.65027
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER6 +++:
Event Name: WindowsUpdateFailure3
Cab Id: 0
Problem signature:
P1: 10.0.17134.677
P2: 80070643
P3: 6125CFDC-F59C-48C5-AF0F-C98FDD2C3F21
P4: Install
P5: 200
P6: 0
P7: 8050a004
P8: Windows Defender Antivirus (77BDAF73-B396-481F-9042-AD358843EC24)
P9: {9482F4B4-E343-43B6-B170-9A65BC822C77}
P10: 0
+++ WER7 +++:
Cab Id: 0
Problem signature:
P1: 10.0.17134.677
P2: 80070643
P4: Install
P5: 200
P6: 0
P7: 8050a004
P10: 0
+++ WER8 +++:
Cab Id: 0
Problem signature:
P1: 10.0.17134.677
P2: 80070643
P4: Install
P5: 200
P6: 0
P7: 8050a004
P10: 0
+++ WER9 +++:
Fault bucket 2054775964926196467, type 5
Event Name: MpTelemetry
Cab Id: 0
Problem signature:
P1: 0x8050a004
P2: ValidateUpdate
P3: N/A
P4: 1.1.15500.2
P5: mpsigstub.exe
P6: 4.18.1904.1
P7: Microsoft Windows Defender (RS1+)
P8:
P9:
P10:
Yay for self actualization! Turns out that when the person who put the PC together assembled it they didn't make sure the graphics card was seated fully. Fortunately I caught it before any permanent damage occurred. Reseated that sucker and now it works like a dream.
