Hello everyone,
New to tom's hardware, very happy to now be apart of the community and hope to learn and share knowledge with all of you.
I have an issue with my first time PC build which I completed in February 2017, these are the parts that I used:
-Intel i5 4460
-MSI h81m-p33 motherboard
-8GB ddr3 ram
-Evga GTX 1060 3gb
-500W Evga psu
Ever since I built this PC I've had this intermittent problem that occurs when I power on the computer, the fans start and run continuously but no display, just a black screen on monitor showing no input. I also have this same problem when I wake the computer from sleep, fans will start but black screen showing no display appears and I hold power button to restart and it will boot normally. Other times this weird situation happens: I power on the PC, MSI splash screen appears, then screen goes black for about 30 seconds (no display input), and then MSI splash screen appears again and boots normally. It seems like half of the time it powers on normally and the other half it doesn't. Other than this problem, PC works great in gaming or just all around general use, no other issues.
I updated the motherboard bios and have all latest drivers and graphics card drivers installed but problem still occurs. I use an HDMI cable from the gpu to the monitor, and I tried out different HDMI cables but no improvement.
The one solution I found that makes this problem go away is if I remove the graphics card completely and display using CPU integrated graphics using the VGA port on the motherboard to the monitor. With no gpu installed, PC starts perfectly every time.
So what do you think this might be, a problem with the graphics card or with the PCIe slot on the motherboard or is this just something normal? I appreciate in advance and thoughts you are willing to share on this and what the problem might be.
-Intel i5 4460
-8GB ddr3 ram
-Evga GTX 1060 3gb
-500W Evga psu
