My friends system was having some issues so he decided to upgrade most of his components as he was in need of an upgrade anyway.
The specs of the PC are:
Motherboard: MSI x570 A Pro (New part)
CPU: AMD Ryzen 5 3600 (New part)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 (New part)
Video Card: Gigabyte Aorus GeForce GTX 1660 OC 6G (New part)
Power Supply: Corsair CP-9020047-UK Builder Series CX500 ATX (Old part)
Storage: Samsung 860 EVO 500 GB SATA 2.5 Inch Internal Solid State Drive (SSD) & WD 1 TB PC Hard Drive - Blue (Old parts)
The issue: Sometimes (about a 50/50 chance) when he boots into windows there is some graphical stuttering (almost as if its skipping a few frames) and there is a very noticeable audio stutter when playing music through Spotify for example. But the other 50% of the time there are no issues when booting into windows (even after gaming for several hours).
As the issue isn't consistently reproducible I'm unsure as to how I work out what is wrong.
I'm thinking it might be CPU related as both graphics and audio are being affected (he's not using NVIDIA HDMI audio).
What has already been tried:
- Reset the BIOS
- Install the latest drivers (including GPU drivers)
- Tested on different monitors
- When I was trying to reset the BIOS, the system was graphically glitching and freezing and was restarting the computer a few seconds after booting into the BIOS (although no such issues with Windows).
- The PSU is 5+ years old.
- I wasn't aware before buying the motherboard that it has an 8pin+4pin CPU power connector.
- His old PSU only has the 8pin connector but most forums seem to suggest the additional 4 pin is only needed if you are doing some intensive overclocking.
- Is it possible the lack of the additional 4 pin could be causing the issue?
