iMac 27” late 2012 high Sierra
Failed to start with internal HDD
Booted with OS on USB external disk
Ran disk utility first aid to check internal HDD
Results below:
volume “Macintosh HD”
Repairing file system.
Volume is already unmounted.
Performing fsck_hfs -fy -x /dev/rdisk0s2
Checking Journaled HFS Plus volume.
Checking extents overflow file.
Checking catalog file.
The volume Macintosh HD could not be verified completely.
File system check exit code is 8.
Restoring the original state found as unmounted.
File system verify or repair failed.
volume “Govind's”
Volume was successfully unmounted.
Performing fsck_hfs -fy -x /dev/rdisk0s4
Invalid index key
Missing thread record (id = 519201)
Incorrect block count for file 2018.09.18.G80.asl
(It should be 85 instead of 79)
The volume Govind's could not be verified completely.
Restoring the original state found as mounted.
Problem -69842 occurred while restoring the original mount state.
Operation failed…
Results below:
volume “Govind's”
Invalid index key
Operation failed…
