Internal PCI sound Card vs external USB sound card?
Makaveliii
77
Hi all. My onboard sound card went bust and doesn't work. I have a 5.1 surround sound that uses RCA to jack cables to work on my PC. I am stuck between which card to get. There is a good one on ebay which is external for a good price but I am not sure whether it is good or not.
Here is the link:
http://www.ebay.co.uk/itm/USB-6-Channel-5-1-Audio-External-Optical-Sound-Card-Adapter-For-PC-Laptop-Netboo-/171236697256?pt=UK_Computing_ComputerComponents_SoundCards&hash=item27de80a4a8
This card looks really appealing as it is cheap and I have a low budget .
Also bear in mind I already bought an internal card but it is too old to be compatible with windows 7.
All I want is a card which has 5.1 outputs that sounds good enough in 5.1 to watch blu ray films to.
Thanks
Check out this card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132052
Not sure what you're going to be doing with your PC but if you're just gaming and watching videos, the 24-bit audio on this card should be more than enough for sound quality. There is also a PCI version if you don't want or have a free smaller PCIe slot.
You may also need to get a converter as the jacks on this card are 3.5mm for your RCA plugs i.e. something like this:
http://www.amazon.com/Audio-Adapter-3-5mm-Jack-Plugs/dp/B000A3GPIS
