C cth338mag Commendable Jan 13, 2017 1 0 1,510 Jan 13, 2017 #1 I am looking for a pci or pci-x or pci-x16 card with internal usb 2.0 header and internal usb 3.0 connector for front case devices.
Solution James Mason Jan 13, 2017 Does you motherboard have NO front panel adapters, even for 2.0? They don't really make combo ones, but you can get a 3.0 one: https://www.amazon.com/Syba-SD-PEX20139-Port-Pcie-Card/dp/B00965J5UG?th=1 This adds more 2.0 internal headers, but needs a 2.0 header to expand off of: https://www.amazon.com/NZXT-IU01-Internal-Expansion-Black/dp/B0031ESKJA If you NEED to add 2.0 headers, you need two separate items, one that adds an internal USB port, and one that converts that port into a header: https://www.moddiy.com/products/USB-9%252dPin-Internal-Motherboard-Male-Header-to-USB-Type%252dA-Adaptor.html https://www.amazon.com/dp/B000QJ15N6
James Mason Titan Jan 2, 2014 13,551 8 74,965 Jan 13, 2017 Solution #2 Does you motherboard have NO front panel adapters, even for 2.0? They don't really make combo ones, but you can get a 3.0 one: https://www.amazon.com/Syba-SD-PEX20139-Port-Pcie-Card/dp/B00965J5UG?th=1 This adds more 2.0 internal headers, but needs a 2.0 header to expand off of: https://www.amazon.com/NZXT-IU01-Internal-Expansion-Black/dp/B0031ESKJA If you NEED to add 2.0 headers, you need two separate items, one that adds an internal USB port, and one that converts that port into a header: https://www.moddiy.com/products/USB-9%252dPin-Internal-Motherboard-Male-Header-to-USB-Type%252dA-Adaptor.html https://www.amazon.com/dp/B000QJ15N6 Upvote 0 Downvote Solution
