Internet and Display problems.
erfdcv
Commendable
Apr 13, 2016
4
So ever since I updated to Windows 10, every time I shut my computer lid and opened it again, the display wouldn't turn on and I would have to restart to turn the monitor back on. I am on an HP Windows 10 laptop. Another problem I've had is that my WiFi will just turn off randomly, the WiFi to only MY computer goes down, everyone else in my house still has internet and everything is fine for them, the only way I've found to get around this is to restart my computer. I have to do this about once every couple of hours. I have tried going into settings and trying to turn the WiFi on there but that never works and usually when the WiFi crashes the settings page won't work and just freezes. I'm sorry if any of this information is confusing, but I really want to fix these problems.
Hi,
Please do try these troubleshooting steps that may help.
- Open Power Options then click on Change Plan Settings then Change Advanced Power Settings.
- Expand Hard Disk then set Turn off Hard disk after to NEVER.
- Expand Sleep and set Allow hyrbid sleep to OFF.
- Set Hibernate after to NEVER.
- Do also set Sleep Mode to Never.
- Click Apply and OK then test it again and see if the same problem will persist or not.
About the Wifi being disconnected, check the Power Management option.
- Open Device Manager and right click on the Wifi Adapter then click on Properties.
- Click on Power Management tab and remove the check on "Allow the computer to turn off this device to save power."
