This networking issue has occurred for a month already, and I sought further assistance from my ISP several times, tho nothing advanced. It's such a frustrating situation. Could someone please look into this case study and find me a bright future for my network at home please? Love you x3000
Problem 1:
Discord frequently restarted when I was in a voice channel (with/without other users in the channel).
Actions:
Reached out to the Discord Diagnosis Team for further assistance. (Reset Router and Modem, Adjust DNS address, Replace all the ethernet cables, Re-installing Discord, Install other versions of Discord).
Findings:
None of the actions above worked out, this is nothing to do with Discord since the problem initially appeared to have occurred even with other devices (PS5 connected with the ethernet cable, Mobile phone connected with Wifi)
Problem 2:
Whatsapp and Messages (Facebook) sent and received several messages at once (should have been sent out or received just seconds later) for mobile phones.
Actions:
I contacted BT for assistance several times via the hotline. They advised me to factory reset the router and modem, checked that everything was fine (internet speed and BT smart hub 2), unplug the external router of mine (which I’ve been using for a year already), Replace the BT smart hub 2 with a new one (they send to me).
Findings:
Initially, the problem had been sorted with all those potential solutions tried. I figured out the problem was not on the cable, my devices (because not only a singular device was affected), and BT smart hub 2, BUT the root could only appear on the modem (Openreach device attached to the wall).
Problem 3:
While having a Zoom meeting for lecturing, the voice of the lecturer appeared to be disrupted (disappeared) for seconds every 20 seconds approx. but the video of him was working (not so smooth tho).
Actions:
I open NordVPN and connected to a Glasgow region server, everything seems worked out fine (smooth and with no disruption).
Findings:
I have no idea how can a VPN could have better stability than my own networking across the same region. But this appears to be a temporary solution in order to carry out a stabilised connection for now.
Temporary Solution 1:
Using VPN
Remarks:
As long as I’m connecting to a server, there is a relatively stabilised connection than when I’m not connecting. I could not believe a VPN could beat my initial connection.. (in terms of stability within the same region)
Important Notes:
There is Packet Loss while I’m assessing the performance of the network connection (https://test.vsee.com/network/index.html)
The disruption happened when the packet loss is at 1~2% usually. (I know it is a small value in packet loss, but it does result in affecting the quality of connection)
Ethernet receive will drop to 0 Kbps mostly when I was having an unstable connection (Loading streams, Restarting Discord Automatically)
Connected to a Glasgow Region Server using NordVPN to watch a stream (broadcasting from Canada) on Twitch.
Normally watching a stream (broadcasting from Canada) on Twitch (without VPN).
Problem 1:
Actions:
Findings:
Problem 2:
Actions:
Findings:
Problem 3:
Actions:
Findings:
Using VPN
Remarks:
Important Notes:
