Internet connection problems
wrsteinjr
Commendable
Sep 10, 2016
I have 3 boys all have Internet access on their playstations, but I can not access Internet on a laptop. My Laptop would show that it was connected but would not access web pages so I thought that I might have gotten a bug of some kind. I recently purchsed a laptop for my son and it wont even connect to the Internet. Any help would be greatly appreciated...
When WiFi won't connect.
First, make sure your laptop is 'not' connected to the modem/router via an Ethernet cable and follow the steps:
1. Go to "Control Panel".
2. Next go to "Network and Internet" and then "Network and Sharing".
3. Now click on "Manage Wireless Networks".
4. On this screen, remove all wireless connections by "right clicking" on it and select "Remove network" from the drop down menu.
5. After doing this, close the windows and scan for the "Wi-Fi networks".
6. Click on the available network that you want to access and select "connect".
7. It takes a moment, but then you will be asked to give a password for your Wi-Fi connection. Type in the password and click the "connect" button.
It should now be...
It should now be connected.
NOTE: If this doesn't work, you may want to reset your modem/router, and then once it is fully loaded again, repeat the above steps.
