Hello,
I've been trying to connect to the internet my Windows 7 Home Premium but it's not working.
On other devices it works fine. The problem is that it will say "Internet Access," but when I try to connect to a webpage or an application that requires Internet Access it will act like its offline.
I've tried many things like typing in "netsh int ip reset resetlog.txt" in command prompt. I've been only able to access the internet on the PC for only a couple of seconds then it will take me offline for about 5 minutes. I've tried to change the DNS settings, system restore, working with netsh, and I also tried to re-install my Wireless LAN card only ending up with the same results; nothing. If you need any other questions in order to help me resolve this problem, please do ask!
Other: I have tried to disable my Anti-Virus, and nothing happened.
-Lenny
-Lenny
