Internet problems, pls help me :(
FranoM
83
When i turn on my pc i have a short window of time when i have internet (around 1 min), but then it stops working for around 5 min, then it is back up. This happens every single time.
How do i fix this?
Can be any number of things. Too far from Wifi point. Low signal quality (how many bars do you get on the icon in the tray). Malware messing up the computers internet. Your illegally on someone else's wifi and they keep trying to kick you off by resetting it. etc.
How about plugging right into your router with a wired connection, does it work then? If so, then standing 5 feet from it, does it work wirelessly? If NO in both, then while wired download Malwarebytes and run a scan to make sure nothing is wrong. If wired doesn't work sounds like Windows (assuming this is even a Windows machine? and not even knowing the version it is) is or the hardware is fragged up and your computer needs to be serviced by a professional.
Considering the...
Considering the cost of them to 'look at' a computer and WIPE IT back to the FACTORY setting (as you took it out of the box the very first time) is over $199 or more, most people find computers (unless specially built like gaming PCs and such) are 'disposable' as they can head to Walmart and for $200-249 get a BRAND NEW WARRANTY backed Windows Laptop and then find some 'computer friend' to get your 'files' off the old PC hard drive for you.
