S sfeath15 Reputable Aug 21, 2014 10 0 4,510 Aug 21, 2014 #1 After building my pc and running a speed test I'm getting 8mb/s download speed and on my ipad I get 30. I don't know what's causing it. The wifi card installed in my pc is the TL-WN951N
Bonesbobman Honorable Jun 22, 2014 85 0 10,660 Aug 21, 2014 #2 Is your PC far away from your router? Upvote 0 Downvote
digitaldoc Expert Ambassador Oct 31, 2003 5,213 0 36,960 Aug 21, 2014 #3 What is the speed from your ISP? What speed are you getting on the iPad? Can you use a wired internet connection and see what speed you are getting? Upvote 1 Downvote
S sfeath15 Reputable Aug 21, 2014 10 0 4,510 Aug 22, 2014 #4 Bonesbobman : Is your PC far away from your router? Not to far away I get good connection on all other devices in the same room Upvote 0 Downvote
S sfeath15 Reputable Aug 21, 2014 10 0 4,510 Aug 22, 2014 #5 I get 30mb/s on my ipad in the same room. Wireless is not an option as my pc is on a different floor to the router Upvote 0 Downvote
S sfeath15 Reputable Aug 21, 2014 10 0 4,510 Aug 22, 2014 #6 I meant wired is not an option* Upvote 0 Downvote
Bonesbobman Honorable Jun 22, 2014 85 0 10,660 Aug 22, 2014 #7 I think you have a crappy WiFi card. Upvote 0 Downvote
