Question Internet Speed stuck at 100Mbps
Jun 23, 2022
I have a CAT 6 Ethernet cable and my motherboard has WIfi 6 and it says it can go up to 2.4gbps and everything is plugged in correctly and my Speed and Duplex is set to Auto Negotiation.
Jun 23, 2022
full system spec? if you are using ethernet, don't matter what wifi you have
connect to what router? modem? hot spot? what the exact model
connects from my pc to the router
Tuf Gaming B-460m-Plus (wifi)
Corsair Vengeance 2x(16)
RTX 3060
i9 10900K
and are you looking for the Router model?
USAFRet
156,078
11,667
176,090
24,257
You're confusing a few concepts here.
Ethernet cable and WiFi....you use one or the other, not both.
Preferably the ethernet
"says it can go up to 2.4gbps"
"2.4" is the frequency, not the speed.
2.4GHz.
Cat 6...this is almost certainly your problem.
Very likely a faulty or non-standard cable.
Try a good quality Cat5e, see what happens.
And also, what specific router model is it?
Jun 23, 2022
2.4GHz.
View: https://i.imgur.com/skAEF5dh.jpg
im not sure but im pretty sure its supposed to be on this and the big crossed out part is the barcode
