inverted ATX case
-HH-
Dignified
Hi,
looking for an inverted atx case to fit a dark rock pro 4 and a gtx 980 matrix within, does anyone have some ideas.
Currently got a corsair 900D but it's just super huge and want to save some desk room.
I'm looking for an inverted atx as I want to have the PC on the left side of my desk with the window still visible.
Would you consider the Corsair 600C? (https://www.corsair.com/us/en/Categories/Products/Cases/Carbide-Series%E2%84%A2-Clear-600C-Inverse-ATX-Full-Tower-Case/p/CC-9011079-WW). It's about 8" shorter and 6" shallower than the 900D.
Built using a much taller CPU cooler (Cryorig R1 Ultimate) compared to your Dark Rock Pro4, and an Asus Strix 1060 (almost similar in size, just slightly narrower, compared to your GPU) https://pcpartpicker.com/b/GYLJ7P
Another sample build (https://pcpartpicker.com/b/wyM8TW), using a CM V8 cooler (just slightly smaller than your Dark Rock Pro4):
maybe, I mean im thinking the dark base 700 might be more for me, granted I'd have move bits in the case for it to be inverted but it makes more sense for me, I've had a lot of bad experience with Corsair support is all
