Iomega LDHD-UP problem
Romas
I have an Iomega LDHD-UP 1TB external hard drive. Today it failed to start. I get a blinking light and a slight beeping sound. What can I do?
If its under warranty contact iomega for an exchange
If its out of warranty you can try removing the drive from the enclosure and placing it in another or using it with a 2.5inch hdd to usb cable.
Odds are though the drive has gone belly up and you will wind up throwing it out so check if any of your friends have a way to check it first before you spend money.
