iOmega NAS drive not connecting
kalam7413
9
Hello,
My iOmega Cloud Edition NAS drive comes on but no network connection there is no input/output activity registering on the network router port nor on the NAS... took the 2TB hard drive out and connected SATA port to USB on my computer. The hard drive is recognized but windows prompts for formatting the hard drive. I need to recover 1.5tb worth of data on it... please help.
DO YOu think REMO Recover can do this as well?
It is a single hard drive, so there should be nothing super complex about accessing the data, other than needing an OS or software that can access the Linux file system on the drive. In this case, you are probably best off using UFSExplorer. It should be just a matter of selecting the drive, selecting the files and saving them out to a target drive.
If you want to go the free route, just mount the drive within Linux. Any live USB/CD version would suffice.
I had started using DMDE but which RAID should I use with my hard drive?
Realized you had also suggested RAID finder... is it easier?
I used RecoverMyFiles as well it shows all the files but no folder structure... would RAID recovery help with that?
When selecting RAID1 it needs two hard drives so that doesn't work... now tried your ISO but its a bootable DVD! Why a bootable DVD for a USB drive?
I need to recover files with the folder structure which is very important as I have 1.8TB of data on it...
But first my PC is not booting up with the bootable DVD... but even if it did I need step by step instructions... do you think you can help me over Webex or Skype desktop share?
