• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
IP-35 Pro stuck on CC post code and no response on power switch
sw0mgt
22
Hi.
First, I was having the following issue:
One day I reboot the computer. Board posts, fans spin, HDDs spin, etc just like every thing is working properly. Except the monitor displayed an empty black screen with the message "No PC signal"! I turned off the computer and cold started. Same issue. I cleared the CMOS jumper in the back, hit start, and voila... every thing works! Until the next reboot or cold boot , where the monitor is black and "No PC signal" I had to clear the CMOS jumper before every restart to get things working properly.
I've been doing this for two weeks before I got some tips. "Try changing the CMOS battery." OK. So I turn the computer off, do some cleaning, try a different battery, re-hook every thing up.... and.... no response on the power button at all. It doesn't even try to boot.
The board appears to be permanently stuck on CC post code. According to my manual, this is the invalid CMOS jumper setting code. Except the problem: both the CMOS jumper on the back of the computer, and the motherboard 1-2-3 pin jumper, is correctly set to the default mode. No combination/alignment of the 1-2-3 pin cap or the CMOS switch on the back removes the CC post code. Except I recall the board being stuck on CC post code and booting up before.
I never suspected a power supply issue, because while the motherboard was having stability issues with RAM, seemed to be stuck on CC post code, and had the monitor problem, the computer (once booted) would successfully idle for weeks at a time.
I'm super confused because nothing's really changed since the moment I unplugged my computer, popped out the battery, did some cleaning, and reset the motherboard jumper. Now pressing the power button doesn't accomplish anything... the board just sits there, lit up, with CC post code.
Minisoft
Push the switch down on the back of the motherboard . under the mouse and keyboard connector.if its up then its in clear cmos mode and wont boot..... i know this is a long awaited reply.. but it might help someone else...
fivecolor5
Thank you, you saved me indeed! This solved my problem with the motherboard that refused to boot, with "CC" display.
Mark_66
Thank you I had an old computer with this board in it, and was fixing it up to give it away and couldn't figure out how to get it to start. Somehow the switch had gotten pressed up, and this was the solution! Saved me lots of time, thanks!
Similar threads
