iP8500 - head priming before printing second side - normal?
G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
I've had no experience of any of the Pixmas, but I bought this to replace a
defunct SC900. The first thing I've noticed is that the automatic duplex is
glacially slow.
Example: - a two-page Word document. Time to print first page: - around 10
seconds. Time to draw paper back in, turn paper over, prime heads and print
second side: - 1 minute+.
I've started using manual duplex as it cuts printing time by about 75%.
Is this normal? Should it be doing all this priming before printing the
second side?
Thanks
Windows XP Pro SP2, printer hooked up directly to a Hi-Speed port. I tried
FireWire (800) didn't make any difference. Not that I'm surprised, a printer
isn't capable of utilising the full speed of either.
> glacially slow.
> second side?
It's perfectly normal. That is, by design. Not by efficiency. I tried
mine (iP5000) but don't use it as it's just too painfully slow, as you
indicated, up to 75% longer than by feeding pages by hand. It's fine if
you want to torture your machine while doing the laundry. ;-)
-Taliesyn
> Thanks
Thats funny, I thought you had an answer for everything.
"Miss Perspicacia Tick" <test@test.com> wrote in message
news:f6Wre.10825$Kt2.3096@fe07.highwinds-media.phx...
> a defunct SC900. The first thing I've noticed is that the automatic duplex
> is glacially slow.
> print second side: - 1 minute+.
> second side?
> Thanks
> printer isn't capable of utilising the full speed of either.
> Programming sotware does not allow for printing even odd pages.
Print
(*)pages [ 1,3,5-1000]
Print
(*)pages [2,4,6-1000]
Even if you don't get the nice and spiffy odd and even button in your
print window you can manualy duplex in this way. Not so good for
printers that leave copy print side down, but great for budget printers
that leave copy print side up. But in the case you have the former...
Print
(*)pages [768, 766, 764-2]
(*)pages [767, 765, 763-1]
> The "nice and spiffy" Odd & Even button is found in all if not most
> word-processing/desktop publishing programs
Oddly enough, I don't see it under Open Office 1.1.4, nor Notepad,
Wordpad, Mozilla Firefox, or Internet Explorer. But if i'm feeling too
lazy to type in 1,3,5-1000 I can select duplex and unclick automatic on
my ip3000 and the driver will prompt me to reinsert the paper.
So as I said... even if you don't get the nice and spiffy odd and even
buttons you can do it easily enough.
> That would be:
> (*)pages [ 1,3,5-999]
> or
> (*)pages [ 1,3,5-1001]
Sure if your paper feed has that many, or if your ink would last that
long. You should be able to pick an arbitararly high number that is
higher than what you plan to print saving you from actually counting
how many pages the end result will be. You could use 888 or 999 if
you're worried about it.
In my case I got in the habbit of typing in 1000 as each paper cassette
would hold 500p on my old panasonic 4450i.
> Notepad and Wordpad are not even stand alone programs but programs
> within programs meant basically for short text handing.
Notepad is very much in common use as a stand alone program for editing
ascii. In fact in win2k and winxp they updated it and added search and
replace, rather than prior versions that were limited to only search.
To each their own. The parent to this sub thread was talking about
programing languages, and notepad does a very fine job of taking a
large amount of code and printing it without any mucking around. I
imagine others might want to shell out money for TSE (formatly Qedit)
which is also very useful in dealing with ascii documents. Needless
to say hardcopy is very useful in debugging, and double sided printing
if nothing else saves paper and space on the shelf.
Wordpad is as you said mostly for short text handeling. For those
without Word it's useful for printing off documentation that comes with
software, which is often a sheet or two. Also it deals with RTF well
enough when again double sided can be useful for printing off
documentation.
> I don't print 20 page documents from a browser (unless maybe it's in
> a printer friendly format). I download and edit within a wordprocessor
> or desktop publisher.
I use Yahoo maps and directions alot. Draft mode page one and draft
mode page two. Very handy. I imagine I could edit the page in
anything that supports HTML, but i'm lazy.
I'm not complaining about the lack of manual duplex support in some
applications, except Open Office that should have it. For the most
part I don't care all that much. I was only pointing out that you can
do manual duplexing even if it's not an option on your print window.
> Print
> Print
word-processing/desktop publishing programs. It's available in MS Word,
Serif PagePlus, Adobe Reader, and Lotus WordPro. Nobody *really* needs
the slow, mechanical duplex feature found on printers.
-Taliesyn
Change the drying time in the driver and it will speed up some. To
print a 10 to 50 page document it is great. Set it and forget it. You
do not have to calculate page breaks and keep changing papers. For a 2
page document it is your call. It is convenient and much less a pain in
the ass to use the duplex feature.
>glacially slow.
>second side?
>Thanks
"Speed up some?" What we need for it is to speed up TREMENDOUSLY as
it takes up to 3 times as long by default while playing Roller Coaster
Hide 'n Seek with the paper (in and out).
> To print a 10 to 50 page document it is great.
NOT if you're sitting there waiting for it to finish. I'd recommend 1
page, not more. That's all my patience (and I actually have some!) can
bear.
> Set it and forget it. You do not have to calculate page breaks and
"Calculate" what page breaks? What are you using, Gameboy? I use OEM
;-) Windows software. The last page break I ever set was on some DOS
word processor for my Atari 1050st computer in the mid-80's - like 25
years ago. Get some new software.
Keep changing papers? How hard is it to change papers only once in a 10
to 50 page document. You print the odd pages first, then turn them over,
and print the even. No sorting required. And you just saved up to 75%
time and mechanical wear and tear of your printer. Oh, I forgot,
Measekite still uses "page breaks". Too bad for him.
> For a 2 page document it is your call.
Funny man.
> It is convenient and much less a pain in the ass to use the duplex feature.
Only Measekite would see "much less pain in the ass" in something that
takes up to 3 times as long and puts unnecessary stress (wear and tear)
on your printer. As for its ability to print a multi-page document
unattended, big deal. I can leave it to print the odd and even sides
unattended as well. I only have to return once to finish the duplex
job manually.
For ultrafast duplexing, when needed, I orchestrate BOTH of my printers
to work together to complete a job. I prefer efficiency and speed over
the lazy man, pain-in-the-ass-slow, Measekite way. Curse me for that,
but that's just me.
-Taliesyn
> Programming software does not allow for printing even [&] odd pages.
Obviously you've never been in an office or you would have known that
Odd/Even printing is a common feature of programs like Microsoft Word,
Adobe Reader, Serif PagePlus and Lotus WordPro, all of which I use
regularly. You only have to click on "Print" and read your menu choices.
-Taliesyn
The programs you mentioned are not wordprocessing or desktop publishing
programs that commonly deal with multi-page documents.
Adobe Reader, for example, is commonly used for reading program manuals
that are often in the hundreds of pages. Thus it has the one button
"Odd" or "Even" button. And naturally, Microsoft Word does too as it is
a document printer. I use the Desktop Publishing program Serif PagePlus
to make booklets sometimes hundreds of pages long. And of course, it too
has "odd/even".
within programs meant basically for short text handing. And my Netscape
doesn't have it either. But then, none apparently do (it's not needed).
-Taliesyn
> Stand alone, as in store bought?
No, stand alone accessory, works fine by it self. Same with Edit,
Paint, Kodak Imaging, and Hyper Terminal. I can for example take
notepad.exe and run it under wine on linux without a problem. It has
no dependencies, requires nothing else to operate other than the
windows enviroment. It's not associated with any particular program
nor is it a program with a program but rather a program onto it self
that is often spawned by other programs because it's almost always
installed. It's location is in the root of where ever windows is
installed. It can be picked independently when installing windows, or
not installed if you take the time to look for it. It is for all
intents and purposes a stand alone program and most importantly
Microsoft says them selves that notepad can be run as a stand alone
program. It is a simple 69,120 byte independent program.
What an odd point to argue.
>> replace a defunct SC900. The first thing I've noticed is that the
>> automatic duplex is glacially slow.
>> around 10 seconds. Time to draw paper back in, turn paper over,
>> prime heads and print second side: - 1 minute+.
>> 75%. Is this normal? Should it be doing all this priming before printing
>> the second side?
> if you want to torture your machine while doing the laundry. ;-)
> -Taliesyn
>> Thanks
>> tried FireWire (800) didn't make any difference. Not that I'm
>> surprised, a printer isn't capable of utilising the full speed of
>> either.
I think this is only usefull if you need to print more pages in duplex, so
you hit print and go away for some time. And when you get back, your job is
done. But if you need it NOW, it's better to do manual duplex, sure.
> ascii.
-Taliesyn
> Notepad is terrible for the purpose. For one thing you loose your color
> coded criteria. For another you loose all of your intellisense data.
> You also loose all of the advantages of the IDE and increase you chances
> 10 fold of creating errors.
Assuming you had intellisense data or color in the first place. There
are more things in heaven and earth and all that. Not every uses a
Visual(tm) compiler nor need to work in a special development
environment. Some people actually know how to write code. If I want
color I'd edit in vi, but I find working in vi to be a pain. I don't
claim to be a programer but never the less there are times that I need
to scan through large amounts of data... and for that hard copy in
Lucinda console or Courier is just great.
> > I
> Another outdated outmoded program.
Outdated? I haven't checked it's unicode support so you could be
right. Outmoded by what? Find me another versatile intermediary
program that allows large amounts of data to be converted. Excel works
most of the time, but excel has it's limitations. TSE -> excel (if
need be)-> portable data.
> -Taliesyn
Hey shmuck! Since when is MS Word a programming language.
Idiot...nobody ever said Word was a programing language.
Frank
> Frank
Frank, he's obviously tried without luck to program his Game
Boy to print odd and even pages. Who are we to interfere.
-Taliesyn
Oh Yeh, for a 50 page document how many reinserts do you make?
Obviously you haven't stepped one foot in a real office or you would
know the answer.
Print all 50 pages one side, turn over the WHOLE PACK OF 50 and print
the other side.
-Taliesyn
> Print
That would be:
or
right?
> Print
> printers that leave copy print side up. But in the case you have
> the former...
> Print
"measekite" <inkystinky@oem.com> wrote in message
news:gc0se.2105$Pa5.876@newssvr21.news.prodigy.com...
Probably around the time it had Visual Basic for Applications embedded
inside it.
Frank wrote:
> Idiot...
> Frank
:-D :-D :-D Yes you are
