Iphone 8+ Front speaker not working after screen replacement
TripleStack
22
Hey, I have recently done a screen replacement on a iphone 8+ and it all went well to my recognition but i soon realised the front speaker failed to work, the cause of this i have no idea, i have done screen replacements on previous phones and this has never happened
Any help would be great, thanks
About all you can do is open up the phone again and doublecheck your work.
And take a look at the front speaker if at all possible.
What was the reason for the original screen replacement? Was the phone dropped?
Sometimes there is hidden damage that does not immediately show up. Or some partially damaged component later fails after initial repairs have been made.
Or Component A is damaged and Component B is in some marginally functional state.
When A is fixed A then causes B to completely fail.
Okay, i will go through everything again making sure its okay and ill get back to you,
The phone was dropped from quite a low hight being very low impact, but ya know iPhones xD
