Ips monitor for £100
There is no 1080 IPS Monitors for £100. But if you're willing to expand your budget by £14, you can get this quality IPS 1080p Full HD 23 Inch monitor from Viewsonic:
Monitor: ViewSonic VA2349S 60Hz 23.0" Monitor (£114.43 @ Amazon UK)
Total: £114.43
Generated by PCPartPicker 2015-08-11 11:14 BST+0100
Cheers!
Total: £114.43
Cheers!
it should be noted... all of the ips panels you will find for cheap are 6bit hence are really no better in terms of color accuracy than tn or va panels. the only thing you might get is a slightly wider viewing angle. the whole reason why ips became a household word is because of the color accuracy improvement which is noticible on 8bit and 10bit panels however those are far more expensive.
I can stretch to about £150 if that will get me anything better.
Are there any 8 bit ones for £150?
