[SOLVED] IPS monitor viewing angle issue
May 31, 2019
4
So i just bought this ips monitor (Asus VG279Q) but there is a orange glow on the bottom right corner of the screen and a same but subtle bleed on the top right corner on black or dark screen when viewing it from the middle. It goes away when looking directly in front of it. The left corner does not have this issue at all.
Here are the images of the issue:
View: https://imgur.com/a/fBmedUg
Is it normal or do i have to send it back for RMA? any help would be much appreciated.
This is the infamous ips glow and why I don't suggest ips with darker images. If it was backlight bleed, it would not go away. The other corners will be different color glow so you may not notice it as much but it's clear from the image that it happens all around as normal ips glow does.
Thanks for your input. Now i know that it's not a defect.
