[SOLVED] IRQL_NOT_LESS_OR_EQUAL and a bunch of other problems. Please help
Dec 23, 2021
I went ahead and moved my computer one day and ever since i have been crashing. it started by me opening Escape From Tarkov and my whole pc froze, and from there i have been crashing with a bunch of other problems such as: KERNEL_SECURITY_CHECK_FAILURE, KERNEL_APC_PENDING_DURING_EXIT, SYSTEM_THREAD_EXCEPTION_NOT_HANDLED. I have had a few more but didn´t take any pictures. i have tried so many things and i just have ran out of ideas on how to solve it, i have no idea what is even causing this. any help will be greatly apreciated.
Try running memtest86 on each of your ram sticks, one stick at a time, up to 4 passes. Only error count you want is 0, any higher could be cause of the BSOD. Remove/replace ram sticks with errors. Memtest is created as a bootable USB so that you don’t need windows to run it
Can you follow option one on the following link - here - and then do this step below: Small memory dumps - Have Windows Create a Small Memory Dump (Minidump) on BSOD - that creates a file in c windows/minidump after the next BSOD
  1. Open Windows File Explore
  2. Navigate to C:\Windows\Minidump
  3. Copy the mini-dump files out onto your Desktop
  4. Do not use Winzip, use the built in facility in Windows
  5. Select those files on your...
  5. Select those files on your Desktop, right click them and choose 'Send to' - Compressed (zipped) folder
  6. Upload the zip file to the Cloud (OneDrive, DropBox . . . etc.)
  7. Then post a link here to the zip file, so we can take a look for you . . .
